Question about Boating
I have an internal server error 500. The second issue is the structure scan only displays a blank screen of the color chosen.
I have an elite 7 to combo
Cryptonteki
  • 97 Answers
SOURCE: Internal Server Error 500
Start Internet Explorer. 2. On the Tools menu, point to Pop-up Blocker, and then click Pop-up Blocker Settings. 3. In the Address of Web site to allow box, type http://v5.windowsupdate.microsoft.com, and then click Add. 4. Click Close to close the Pop-up Blocker Settings dialog box.
Posted on Feb 16, 2008
pagebor
  • 2785 Answers
SOURCE: An unexpected internal error has
scan your pc for viruses by disabling the system restore then reinstall the driver for the scanner
Posted on May 16, 2008
  • 14 Answers
SOURCE: PHP Error 500
Internal Server Error 500 is usually caused by either a malformed cgi script or an invalid directive in an .htaccess file located either in the same directory as the page throwing an error, or in any directory above it.
Have you recently uploaded or editted an .htaccess file that includes mod_php related directives such as php_value ..., php_flag ...?
If you did start your search there.
Posted on Aug 28, 2008
SOURCE: DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Posted on Dec 03, 2008
Derkek
  • 7 Answers
SOURCE: The server encountered an internal error
just refresh...if that doesnt work Re-type the youtube address if that doesnt work try a different brower...if u dont have another browser download some
konquerer, opera, firefox, flock, chrome
Posted on May 16, 2009
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
Website not displayed error http 500
The Web server (running the Web Site) encountered an unexpected condition that prevented it from fulfilling the request by the client (e.g. your Web browser or our CheckUpDown robot) for access to the requested URL.
This is a 'catch-all' error generated by the Web server. Basically something has gone wrong, but the server can not be more specific about the error condition in its response to the client. In addition to the 500 error notified back to the client, the Web server should generate some kind of internal error log which gives more details of what went wrong. It is up to the operators of the Web server site to locate and analyse these logs.
500 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with the Web server:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '500'. (Last updated: March 2012).
Fixing 500 errors - general
This error can only be resolved by fixes to the Web server software. It is not a client-side problem. It is up to the operators of the Web server site to locate and analyse the logs which should give further information about the error.
Fixing 500 errors - CheckUpDown
Please contact us (email preferred) whenever you encounter 500 errors on your CheckUpDown account. We then have to liaise with your ISP and the vendor of the Web server software so they can trace the exact reason for the error. Correcting the error may require recoding program logic for the Web server software, which could take some time.
Jan 28, 2013 | Facebook Social Network
Windows Internet Explorer Errors on this webpage may cause it to work incorrectly
Internet Explorer users may experience frustration when the Internet browser displays an error code, especially if the error causes them to lose work or data.
However, many error codes can give insight into why the problem occurred and how it can be prevented it in the future.
Errors
Internet Explorer may display HTTP status code errors if it cannot display the webpage.
There are five classes of status codes that begin with the numbers 1 through 5. Each status code consists of three digits. 4xx describes client (user) errors.
4xx error codes include:
400 Bad File Request denotes inccorect web address syntax such as improper punctuation or capitalization.
401 Unauthorized denotes incorrect credentials (username and password). Users can attempt to access the page with different credentials.
403 Forbidden/Access Denied occurs when the server blocks access. The website owner may have instructed the server to block access to specific files or directories.
404 File Not Found denotes a missing webpage/file. This occurs when another site uses an incorrect link or the user incorrectly enters the website URL. Double check the address.
408 Request Timeout denotes that the the user or
user's computer stopped the request before the server could complete it.
According to Marc Liron, whom Microsoft has award the Most
Valuable Professional (MVP) award for his technical knowledge and community support, the 408 error can occur because the "user will either hit the stop button, close the browser, or click on a link before the page loads." Refresh the page to correct the issue.
5xx Errors b> Unlike 4xx status codes, 5xx status codes describe errors caused by the server that houses the webpage or file the user wants to access.
5xx errors include:
500 Internal Error denotes a server configuration issue. The error page may instruct the user to contact the website administrator and may provide a contact e-mail as well as additional information about the error.
501 Not Implemented denotes the server's inability to perform the request.
503 Service Unavailable denotes a temporary server status. The server may be overloaded or down for maintenance. Other Errors b> Internet Explorer may display a prompt that alerts the user of a javascript error or display a small triangle with an exclamation point (!) in the status bar at the bottom of the screen.
According to the UpdateXP website, Internet Explorer may display a "52 Runtime Error." http://www.updatexp.com/internet-explorer-error-messages.html This occurs because a javascript cannot find a file it requires. http://www.mediacollege.com/internet/javascript/basic/error.html You may be able to solve this issue by clearing your Internet cache.
Javascripts may also experience syntax errors when the website developed has made a mistake when writing the javascript. Website visitors typically cannot fix syntax errors because the website owner must edit the javascript. However, you can look for a way to contact the website owner to alert him or her of the issue.
Jan 27, 2013 | Microsoft Windows Vista Home Premium...
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
Opened an email and it said http/1.1 500 internal server error
That is a rather general error from an internet server. They usually occur when you are visiting a web page that can't be displayed properly due to errors in the code, in this case, they were trying to display HTML code from their system directly in your email. If it came in a spam email, you don't need to worry about it.
If it came from a company or person that you needed to see what they were sending you, contact them and tell them you got a 500 server error, and forward them the email so they can figure it out. It will have to be fixed on their end
Oct 28, 2009 | Apple iMac G5 Desktop
I keep getting a HTTP Error 500 message
HTTP Error 500 means the code that is rendering the web page for the web site you are using has failed for some reason (Server Error). It is not the phone itself.
Oct 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Aug 28, 2009 | Konica Minolta bizhub 200 Printer
No UBI Forgotten Battles 1.22 games lobby
If your having an internal server error it usally means that There Servers are playing up
you cant really do anything about this dirctly but UBI is bound to be fixing it at this moment in time
if you wait a few days they will have fixed it for you.
please rate "
Dec 17, 2008 | Video Game Consoles & Games
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Http 500 internal errors
Try using the latest version of FireFox instead of the browser you are currently using. IE sometimes have issues with complex websites **** as facebook.
You can download it from here:
http://www.mozilla.com/firefox
Oct 23, 2008 | Computers & Internet
Boating Logo
32 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
