Question about Pentax Cameras
Where can i get a manual forthe pentax water pump cam 50
  • Pentax Master
  • 5,412 Answers
Although it has a manufacturer's name of Pentax, I don't think this is a camera. Industrial Machinery may be a better option.
Posted on May 06, 2017
Adjusting my Pentax hydromatic H1 water pump
we need wiring diagram for achromatic 1. the power supply is 240 v 50 hz
Nov 26, 2012 | Cars & Trucks
Pentax Cam 100 pump blowing capacitors. Fitted new motor as the old pump did the same
Are you sure the rotor on the motor is rotating freely and getting up to full speed? Did you try running the motor without attaching the housing that actually pumps the water?
Jan 17, 2018 | Pool & Spa
I got an used Pentax CAM 100 water pump but need some help: Does anyone has manual where I can read the specs and installation guide? Seems it works with split-phase 220V 60Hz. It is possible to run...
Look on the pump itself for wiring instructions. Usually if a pump can be wired to multiple voltages there is a diagram either on the side of the pump or under the wiring cover. I tried to locate a manual online with no success. If it can be wired 110 volts, you will get the same performance but your amperage will be double the 220 volt amperage.
Dec 07, 2010 | Plumbing
How to use pantax mz-50
Hello and Welcome to FixYa!
I've uploaded the manual in 3 parts, you can download them for free from the links given below, I hope after reading it the cam will be handy for you. If in case you are still in trouble about something specific do ask. We are here to help.
Concerned, Nooh
Manual Part 1
Manual Part 2
Manual Part 3
Aug 13, 2010 | Pentax MZ-50 35mm SLR Camera
When should a get the timing belt replaced?
It is critical that you replace the cam belt at 90,000 miles on the 4 cylinder and V6. Both engines are interference engines and as such if the belt breaks serious engine damage will occur. The water pump is also driven by the cam belt so to save labor costs later on have the water pump replaced at the same time you replace the cam belt. Have the cooling system flushed, thermostat replaced, and a fresh supply of a 50/50 mix of antifreeze and distilled water installed. You will be good to go for another 90,000 miles.
Jan 27, 2010 | 1996 Honda Accord
Where can i get a free instruction manual for my pentax mz-50 camera
Try this: http://www.butkus.org/chinon/pentax/pentax_mz-50/pentax_mz-50.htm
Nov 11, 2009 | Pentax MZ-50 35mm SLR Camera
Setting up Digital Camera as web cam
I can't get mine to run as web cam either, but run it from mains power with an adapter I got.
Its a small transformer with variable voltage and I set it to 3volts or whatever and then plug in the appropriate connection out of the range of connectors that came with the transformer (its thin and long).
Even then the connection is not very good and I need to make sure the camera stays still or it looses power.
Oct 02, 2007 | Pentax Optio 50 Digital Camera
Cameras Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
