Question about Miscellaneous
2017 vw polo 6auto had rear damage dont want to seleck out of park only when I overrde gearlever I can seleck it to drive if I drive dont want to change over stay in one gear
Moemienag@g
3dmaster
  • 183 Answers
SOURCE: 2001 vw polo
Dear Customer,
check your sensors 1st,all sensors must be good
if all sensors are working good than check your engine firing sequence,some times happens when sequence was wrong,
check your exhaust and carborator tuning pin that creates the batter combination for firing in bore for batter performance & less emitions ,so check is it ok or not than go to your nearest service center that havad certified mechanics,
till you read this you had solve this problem definatly,
THNX
Posted on May 18, 2008
cargurudude
  • 26 Answers
SOURCE: Airbag light remains on after changing fuse of rear wiper.VW POLO
This is a common occurance in vw's.
In order to turn off the airbag light you need to have a scan tool hooked up to your car because the airbag detected a fault of some sort, or it could be a faulty component in the airbag system itself.
Posted on Mar 04, 2009
  • 89 Answers
SOURCE: removing plastic engine cover from 2005 VW Polo
the cover just pulls off and disconnect breather hose as u lift it.there is about 15 screws to remove then the cover opens
Posted on Jul 12, 2009
  • 1071 Answers
SOURCE: can you adjust polo rear brakes at the wheels or
hand brake is the only way to adjust them properly you can adjust them at the wheels but you will need to remove the drums then if adjusted too far drums may not go back on
Posted on Aug 19, 2009
  • 324 Answers
SOURCE: Removing VW polo 2005 battery?
Removing a battery from a Beetle is a bit complex and tricky. I just changed the battery in a 2003 2.0 Beetle. However, the process is very similar in a TDI Beetle. You will need more than your standard generic tool set in order to complete this task. Your tool list needs to consist of a pair of pliers (prefer locking type), a # 20 TORX head screwdriver (You will also need this if you ever plan on changing the Beetle's internal dash pollen filter for the A/C. ), a 10 mm and 13 mm sockets, a long extension and a wobble or universal to allow flexibility in tight spaces, an allen socket for removing the power steering reservoir, and a small adjustable wrench or a 10mm to remove the battery cables. If you are changing the battery you might as well buy a new Air filter since you will need to remove the air box in order to replace the battery. If you do change the air filter you will need a phillips head screwdriver.
1. Pop the hood.
2. Remove the two 10 mm bolts that hold down the air filter box.
3. Undo the clamp that holds the large tubing to the air box using your pliers. Move the tubing away from the box.
4. Unclip hose attached to the back of the air box near the large hose (under it).
5. remove the small breather hose from the air box.
6. Pull air box up and out.
7. Remove snap on cover from top of battery.
8. Remove small snap on wiring cover from back of the battery covering.
9. Unbolt power steering reservoir (next to battery case).
10. Disconnect the battery cables. Positive side first.
11. Remove the 13 mm bolt at the base of the battery along with the hold down clamp.
12. Pull the top wiring away from the battery case and then slide the battery towards the engine.
13. Remove the plastic battery case.
14. Remove the battery
Posted on Oct 07, 2009
Knocking noise heard from rear of vehicle while particularly driving slowly in a parking lot.It is a 2004 Vw Polo 1.2
Check rear wheel bearings. Also if your rear tires are worn I had broken cords and caused a thumping noise at slow speed. Bad shocks will make a noise if running over bumps.
Apr 01, 2016 | Washing Machines
Is there a light in the center console of unidentified vehicle where you shift into drive? reverse, park?
Usually there is a light there fastened to the lower part of the gearlever and a mask as part of the gearlever position markings so it appears the selected position illuminates.
The models I have been associated with use a low wattage bulb of 1.5, 2.2 or 4 watts.
Gaining access for replacement can be a simple or a protracted affair. Sometimes it is a largely intuitive process and sometimes instructions are needed to prevent damage to delicate items of trim.
Oct 17, 2015 | Cars & Trucks
I have a vw polo 2002,when stuck in traffic or after long drive,the ar goes off
does the temp gauge reach the red area? check eng coolant .Over heating could cause eng to cut out so as not to cause more damage check the cooling system.When travelling slowly or at stand still turn heater to max heat and max speed this will cool eng but is only a temporary solution
Mar 26, 2014 | 2002 Volkswagen GTI
My VW Polo 2001 air bag sign is on all the time. Is the car safe to drive and can I take it to any auto electrician as the vw people are so expensive even for a service
music to my ears,YOU take your car to a VW dealer to get it on the diagnosic machine,THEN you take it to your favourite mech to work on it.the diagnostic computer only gives codes,it dont tell you whats wrong,so get a written report done.i am a fully qualified tech and i get my own done this way,as its cheaper.........(mickey mouse diagnostic computers only give codes NOT itemised faults)
Jan 25, 2011 | 2002 Volkswagen Golf
Hi i hit my mark 3 vw golf into a ditch and now the left hand side wheel is bent and possibly the ball joint or drive shaft. Will i be able to use parts from a vw polo of similar age. Will the vw polo...
Simple answer: No. Polos and Golfs use different mechanical components.
More complicated answer: If there is that much damage then the bodyshell mountings are also quite likely to be distorted which will make any repair attempt futile. Ideally you must get the damaged parts stripped off and then get the mounting points accurately measured. This can only be done using specialised measuring equipment. The alternative is to invest in the parts needed for your repair and to fit them with an immediate alignment check at the nearest suitably equipped garage. If the alignment of the body is off then the car is effectively a write off as repairs will exceed the car value.
Oct 06, 2010 | 1997 Volkswagen Golf
I have '98 Polo that has been laid up for 6months.
Brakes wont rust over in 6 months. Sounds like the parking brake is stuck. Check the parking brake lever for slop and free play. If it goes up and down with no force the release catch is stuck. Use a flathead screw driver and manually trip the release. Hope this helps.
Jun 30, 2010 | 1998 Volkswagen Golf
Mk1 VW Polo drops out of gear on over-run
more likely to be a worn baulk ring.do yourself a favour and rebuild the box,its so much easier and will last longer.to test,apply slight hand pressure to gearlever in drive and over run if it slips out......its time for a rebuild....
Jun 15, 2010 | 1986 Volkswagen Golf
Vw polo car wont start
try disconecting the coolant temp sensor and then try, it may be faulty, also check the hall sender unit in the distributor, if it has one, the centre pin should be the signal wire if no pulse is present the sensor is faulty
Jan 03, 2009 | 1997 Volkswagen Jetta
Miscellaneous Logo
12 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
