Question about Maytag Dryers
I have a Maytag MDE9206AYW and need to test the timer switch. How do I do that?
5 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: Maytag MDE9206AYW will not heat. What do I need
I assume it is a gas dryer. Turn it on and if no clicking sound is heard within 30 seconds the spark ignitor needs a replacement. If it is an electric dryer you need to check the relay for the burner system first
Posted on Apr 16, 2010
SOURCE: need diagram for belt replacement on maytag dryer
this website sucks
Posted on Jun 27, 2010
  • 909 Answers
SOURCE: Maytag Dryer model DE212 no heat everything else works? Checked sensors and switch block on drive motor all seem to be ok how to test timer switch?
the heater element may of burnt through, or they may be a red reset switch on the rear of the dryer.
Posted on Nov 17, 2011
machinetech7
  • 1344 Answers
SOURCE: How to remove top and front panel on Maytag Dryer model MDE9206AYW
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
Posted on Jun 07, 2012
Changing belt on Maytag electric dryer model #MDE9206AYW
Go to www.repairclinic.com and enter MDE9206AYW. You will be presented with a list of common parts and may be able to view a video showing disassembly.
Jul 29, 2016 | Maytag Dryers
Maytag MDE9206AYW won't start
When "they" say the timer can't be tested, what they mean is testing is not practical. If your machine uses an electromechanical timer, you can access the inner workings and observe operation and test control voltages for far longer than the time required to oder and install a replacement.
Jan 11, 2014 | Dryers
Jun 06, 2012 | Maytag Dryers
Mde9206ayw won't heat
Check your heating element. If it's not broken (the coils), then you have either a bad thermal cut-off, fuse or thermostat.
May 06, 2012 | Maytag Dryers
Apr 16, 2010 | Maytag MDE9206 Dryer
My Maytag MDE9206AYW runs but won't heat
Had this problem right before Christmas on same dryer. Mine is 9 years old.
Lint had built up in the exhaust hose between the dryer and the wall. Vacuumed it out.
Runs like a champ now.
Jan 18, 2010 | Maytag MDE2400A Electric Dryer
Maytag model MDE9206AYW will not heat. Checked coil, fuses and limits and am now trying to check cycling thermister. Can you tell me how? also do you have any suggestions. suspect dryer went out during...
My generic wiring diagram doesn't show this dryer uses a thermistor, only thermostats. The difference is a thermistor has to have an electronic control to interpret the values the thermistor is sending. A thermostat is mechanical and only open or closes at a preengineered temperature. You would need to check the ohm readings of a thermistor at different temperatures to test it, but you only need to know continuity or no continuity to test a thermostat. First make sure you have 240 volts to the dryer, the heater is the only part that needs 240 to run. It's possible for only half of the breaker to trip and give the dryer only 120 volts, in this case everything but the heater would run. If you've got 240 volts, to the dryer, unplug it, then check for continuity between the 2 terminals of the 2 thermal fuses, cycling thermostat, and hi limit thermostat and heater. Remember you must disconnect one wire before testing to prevent incorrect readings. If it still runs, just no heat, the 2 thermal fuses should be ok, but check them anyways. If they all test ok you'll need to check the temp selector switch. You'll need the wiring diagram to show which terminals to check at each heat setting. If that checks out you'll need to move to the timer, again you'll need the diagram. If the timer checks, the only thing left is the centifugal switch in the motor, and the only way to check that is to test it with the motor running.
Jul 18, 2008 | Maytag Dryers
Maytag dyer MDE9206AYW
moter bad
start switch wont ingage
Jun 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
