Question about Pool & Spa
Where can we buy an Intexpool cover for a 6000lt round steel frame pool diameter 3.6meter
  • 366 Answers
SOURCE: pacer does not run on INTEX pool pump, no
make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Posted on Feb 03, 2010
  • 10865 Answers
SOURCE: I need the instructions to set up a 18 round metal
Hello. Go to the link below, enter the model and year of your pool and then you can select a video and or a downloadable manual of instructions. Joe
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on May 07, 2010
  • 10 Answers
SOURCE: how much salt for 7000gal or 18x52 intex steel
To start up you'll need 175 pounds (80 kgs) When the Low Salt light comes on, add 45 pounds (20kgs)
Posted on May 28, 2010
john224
  • 1378 Answers
SOURCE: HOW MUCH WATER IN INCHES AND GALOONS DOES A 10FT
It will hold ~1175 gallons assuming it is filled to 24" deep. The formula is pi x radius x radius x depth x 7.48.
John
Posted on Mar 14, 2011
  • 1631 Answers
SOURCE: I have a 15 ft diameter round pool with 4440 gal (16806 litre) capacity. Approximately how much salt is required in kilos?
A 15' round pool with a 48" wall has approximately 5300 gallons
That same pool with a 52" wall, has 5800 gallons
5300 gallons of water with No / 0 salt, needs...
About 150 lbs
of salt,
Or about 60 - 70 Kg's
3200 ppm of salt is what you're looking to achieve.
Posted on May 03, 2015
How many gallons does a 15' round pool 35 deep have
Basic school maths Pi R Squared, but are you sure this pool is 35 FEET deep?
Pi, (3.142) x radius squared
the radius is half the diameter x itself, x depth. and then
There are 7.48 gallons in cubic foot
Your pool diameter is 15' diameter, so 7.5 radius. 7.5 x 7.5 is 56.25. Multiply that by the depth. Multiply that answer by 7.48 gallons
Area of Circle
May 25, 2016 | Pool & Spa
What is white round item that I suctioned out of plumbing?
How to Reduce High Pressure in Your Pool System ...
www.inyopools.com > How To Guides
Or every time you turn the pump off, the back pressure is so high that it blows the cover off ... One filter manufacture has suggested putting DE material into the creases of the pleats to ... high spa pressure - If your system had been working in either spa or pool mode, .... The filter seems to operate under too much pressure.
Troubleshooting pumps - Mc Nally Institute
Dec 28, 2015 | Pool & Spa
About 150 lbs
of salt,
May 03, 2015 | Pool & Spa
How much salt do i need for a 15ft round by 4ft deep pool
  • Calculate your gallons of the vessel.
    • On Avg. 15' x 4' pool = 5,000 - 5,500 gallons
    • Then identify current level of salt.
  • If 0 - you will need about 150 lbs to bring to minimum 3200 ppm
Apr 30, 2015 | Pool & Spa
How many gallons of water in a 24 foot round pool that is 52 inches deep
18,600 gallons (length x width x depthx 7.51 =gallons)
Aug 23, 2014 | Pool & Spa
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
Hi where can i puchase a replacement burner cover 11" diameter. model no. JDS-03PCB. cheers
I had my stainless hard cover fab'd at my local sheet metal shop for $10 and the soft covers made at a boat top place for $20.
Much higher quality than OEM.
Aug 30, 2011 | Stainless Garden Sun Steel Propane Patio...
85 pontiac firebird 5L engine automatic trans trans willnot shift until it is totally warmed then shifts normal
Sounds like you might have a stuck governor valve. It is located on the drivers side near the rear, under a round steel cover about 3 inches in diameter.
Jul 10, 2010 | 1985 Pontiac Firebird
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
