What are TPN's used for? - Computers & Internet
My hp laptop TPN-C126 has power but its screen was totally blackout
that TPN-c126 is not the model number
In fact its the EPA/EU, power (sleep )and energystar
regulations RMN:TPN-C126 (the R means gov. regs)
proof here:
http://h22235.www2.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/europe_erplot3_notebo_201542919128520.pdf
if you look again at the back of pc. base.
on the right side of where you where looking
is a SERIAL.(I dont want that)
then below that, is model
"HP 255 - G5" (or very close)
when posting use real names and models
as seen here
http://partsurfer.hp.com/search.aspx
click Hierarchy
then notebooks
then hp notebook PCs
behold. photo below.
one is yours, matching words on bottom of your PC.
LT black screens
http://pcdied.com/black-screen.html#Laptop
below is your pc if you knew its real name.15cdf60c-9764-4e4a-a480-66af380fe0ab.jpg255-g5-hmzm4reoidw0tx1unypabkrd-3-2.jpg
Jul 21, 2017 | HP Computers & Internet
My HP laptop TPN-C126 can not display.
how old this thing.?
take the battery out heat, big one.?
if CCFL lamp, backlite they all go dead, see data on the screen
with a flash light,? yes, bad backlight.
i guess its LED>
is the screen 100% dead at all times, if you see text its NOT DEAD.
is the fan dead?
How to downloadbluestaks
Hi,here is the link. mark all -> click righ on marked text and choose open in new tab. DL should start automatic.
http://r2.computerbild.de/exec/r2r.pl?m=w-cobi;u=http%3A%2F%2Fd.computerbild.de%2Fdownloads%2F3723306%2FBlueStacks-SplitInstaller_native.exe%3F__cbodl__%3D1365264006_b82ba8d46fb4a8ab4c036fafd710cc53%26_chksum_%3Dbb1038cd6ec343289c3768b20b0e0cda;ct=1;thc=1;b=3723306;c=6472017;***=BlueStacks+App+Player+0.7.9.860+%28Beta%29;url=http%3A%2F%2Fwww.computerbild.de%2Fdownload%2FBlueStacks-App-Player-6472017.html;sep=%7C;tce=%7C;tid=36486;tn=Virtualisierung;tp=95%7C362;tc=95%7C362%7C36486;tpn=Software+Kategorie%7CTuning+%26+System;cs=1
Regards
Gue. ;-)
Apr 05, 2013 | Computers & Internet
Windows vista install
Hello Mario.
Try to use this. It`s a freeware tool to setup any Win OS from USB.
I use it for installing Win 8 and work`s fine.
Copy the whole link to your browser and get it.
It`s from Computer Bild a site to download many free Prog`s.
http://r2.computerbild.de/exec/r2r.pl?m=w-cobi;u=http%3A%2F%2Fd.computerbild.de%2Fdownloads%2F2397858%2FWin_Setup_1_0_beta8.zip%3F__cbodl__%3D1362314933_cf939dd66bdedaac4bdcabeddeea6167%26_chksum_%3Db06a3ada611a8e602968aa622d3534a4;ct=1;thc=1;b=2397858;c=4353983;tit=WinSetupFromUSB+1.0+%28Beta+8%29;url=http%3A%2F%2Fwww.computerbild.de%2Fdownload%2FWinSetupFromUSB-4353983.html;sep=%7C;tce=%7C;tid=36485;tn=USB-Tools;tp=95%7C362;tc=95%7C362%7C36485;tpn=Software+Kategorie%7CTuning+%26+System;cs=1
Mar 03, 2013 | Acer Aspire Computers & Internet
Compaq system board 686,0MB (320756) board manual
That's an old mainboard (Motherboard), used in a Compaq Presario 5716 desktop computer. (And perhaps a few other Compaq Presario's)
1) Uses a Slot 1 (Intel) processor slot.
http://en.wikipedia.org/wiki/Slot_1
2) Maximum Intel Slot 1 processor that can be used, is an Intel Pentium III, with a 100MegaHertz Front Side Bus. (100MHz FSB)
Maximum frequency rate for the processor is 700MHz.
('Speed')
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Katmai%29.html
(Scroll the page down)
3) Ram memory is SDR Sdram at 100MHz. Or also known as PC-100. (168 pin. 82 on each side. Two Locating Notches on bottom. Commonly just known as Sdram, but that is a misnomer)
http://en.wikipedia.org/wiki/PC100
Maximum TOTAL Amount of ram memory is 384MegaByte.
Maximum Amount for each ram memory slot is 128MB.
There are 3 ram memory slots.
4) Do not know what the jumper settings on the motherboard are.
5) Do not know what the Front Panel header pinout is.
6) Can run Windows XP Home Edition, but do not expect a world of performance.
Regards,
joecoolvette
Jun 10, 2012 | Compaq Computers & Internet
Master reset code for nokia 1202-2 IMEI # 358016/03/449348/0 CODE:0562271
Nokia Mobile Sets Secret Codes
Mobile Set: All Nokia Mobile Sets
Use For: Default Security Code.
Code: 12345
Mobile Set: Nokia Mobiles
Use For: Turn On Enhanced Full Rate Codec.
Code: *3370#
Use For: Turn Off Enhanced Full Rate Codec.
Code: *#3370#
Use For: Turn On Half Rate Codec.
Code: *4720#
Use For: Turn Off Half Rate Codec.
Code: *#4720#
Use For: Show Software Version.
Code: *#0000#
Use For: Also For Show Software Version.
Code: *#9999#
Use For: Show IMEI (International Mobile Equipment Identity).
Code: *#06#
Use For: Show Lock Status of Your Nokia Mobile Set.
Code: #pw+1234567890+1#
Use For: Show Lock Status of Your SIM.
Code: #pw+1234567890+4#
Use For: Show Security Code of Your Mobile Phone.
Code: *#2640#
Use For: Reset Game Score And Timer.
Code: *#73#
Samsung Mobile Sets Secret Codes
Mobile Set: All Samsung Mobile Sets
Code: *#06*
Mobile Set: Samsung 811
Use For: Unlock code / Change roaming code / ID.
Code: 47*869#08#9
Mobile Set: SGH-600 , SGH-2100
Code: *#9999#
Use For: Show Software Version (instructions).
Code: *#0837#
Use For: Show Serial Parameters.
Code: *#0001#
Use For: Activates the smiley when charging.
Code: *#9125#
Use For: Battery status (capacity, voltage, temperature).
Code: *#9998*228#
Use For: Program status.
Code: *#9998*246#
Use For: Change Alarm Buzzer Frequency.
Code: *#9998*289#
Use For: Debug screens.
Code: *#9998*324#
Use For: Watchdog.
Code: *#9998*364#
Use For: EEPROM Error Stack - Use side keys.
Code: *#9998*377#
Use For: Trace Watchdog.
Code: *#9998*427#
Use For: Change LCD contrast - Only with version G60RL01W.
Code: *#9998*523#
Use For: Memory status.
Code: *#9998*636#
Use For: Jig detect.
Code: *#9998*544#
Use For: SIM File Size.
Code: *#9998*746#
Use For: SIM Service Table.
Code: *#9998*77
Jun 03, 2012 | Nokia Cell Phones
I need a fuse diagram for my 2003 ford ranger 2.3L engine
I don't know if this will help you but here are the location numbers. Can't figure out how to copy a picture of the box itself. I do have an entire owners manual I could send you as a PDF if you need it. Hope this helps. Good luck.
Description
1 50A** I/P fuse panel 2 - Not used
3 - Not used 4 - Not used
5 - Not used 6 50A** Anti-lock Brake System (ABS)
pump motor
7 30A* Powertrain Control Module (PCM)
8 20A* Power door locks, Remote entry
9 - Not used 10 - Not used
11 50A** Starter relay, Ignition switch
13 20A* 4x4 Motor 14 - Not used
15 - Not used 16 40A** Blower motor
17 20A** Auxiliary cooling fan 18 - Not used
19 - Not used 20 - Not used
21 10A* PCM memory 22 - Not used
23 20A* Fuel pump motor 24 30A* Headlamps
25 10A* A/C clutch solenoid 26 - Not used
27 - Not used 28 30A* ABS module
29 - Not used 30 15A* Trailer tow
31 20A* Foglamps, Daytime Running Lamps (DRL)
32 - Not used 33 15A* Park Lamp
34, 35, 35, 35 & 37 Not used 38 10A* Left headlamp low beam
39 & 40 Not used 41 20A* Heated oxygen sensors
Jan 28, 2011 | 2003 Ford Ranger Regular Cab
HOW DO YOU TELL IF 3,3 1/2 PR 4 TPN UNIT
Hi, you tell by the BTU"S it is. 12,000 BTU'S equal 1 ton of cooling. So, if you see a number in the model number like 024 or 030, and so on, 024 is a 2 ton, 030 is a 2 1/2 ton. Just remember this for each ton of cooling, you will have 12,000 BTU'S.
Shastalaker7
024, 030,36,042,48,060.
Jun 12, 2010 | Intertherm P3RA-042K Air Conditioner
Cannot link to wireless thompsoncontrollerinternet
it maybe a firewall blocking access or the secruity code 1) disable the firewall and see if it now connects 2) log into the router and goto the wireless section and remove the secruity now see if that will connect a useful tool to use, if you can copy onto the PC, http://www.xirrus.com/library/wifitools.php this will detect all the networks broadcasting - so you can now see if the adapter will detect your wireless network
Mar 15, 2010 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
