Diagram of water lines for 2010 Keystone Passport bumper pull camper
Bought this RV used with no manuals and need the schematics for the water system
  • 659 Answers
SOURCE: Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Posted on Mar 31, 2009
SOURCE: How do I get an instructional manual for the awning on my RV?
kindly download the manual from the following website
http://bryantrv.com/owners.html
thank you
Posted on May 18, 2009
  • 1129 Answers
SOURCE: 99 ford f250 truck 5.4 need vacuum line schematics
Try ebaymotors they have repair manuals on cd that are inexpensive and have electrical schematics as well as vacuum diagrams. $15.00 - $20.00
Posted on Aug 06, 2009
  • 1779 Answers
SOURCE: water leak in travel lite truck camper has caused
Hi brad, I had the same problem with a camper. I do not know of any available schematic, but would recommend dis-assembly of ceiling area to fix. It's not any easy job, but the only way to fix it properly. Remove all water damage section, make sure water is not pooling on the exterior roof. If it is collecting on the roof, you must brace it from underneath to raise any 'dips' so it sheds water, and make sure you apply a sealing coat (available at trailer stores, or on line) on the exterior. Also, if you park the camper when not in use, make sure you tilt it to help shed water more quickly. You have to use your carpenter and auto body skills to fix this. Don't put it off, I did and the roof deteriorates very quickly once you notice you have a problem. To remove plywood that is damaged, use a skill saw set at the minimum depth (thickness of the plywood) so you don't cut thru anything else. Use a drill to determine the thickness. To install new plywood, cut to fit the opening(s). Next get 3" wide by 3/4" thickness boards, place above cut out area, half on existing ceiling, half hanging over cut out, screw in thru existing ceiling into boards, attach replacement piece, screw into overhanging boards. You can putty over the joints, sand sand and paint, or just glue some sort of fabric to cover the area and make it look finished. Good luck!
Posted on Sep 14, 2009
FixinFax
  • 3085 Answers
SOURCE: Fender Passport 250 PA goes into protect mode
Good Luck.
Posted on Jan 23, 2010
The countertop extension is missing on the camper we just purchased and I would like to replace it; is there anywhere we can order replacement parts that go with our specific camper?
If you want to pay full retail + more, contact Keystone. If the brackets are still there, you could mount a wooden cutting board to the hinge brackets. If you need brackets, they are available at home improvement stores. A section of matching or contrasting countertop can also be purchased there.
Mar 23, 2017 | RVs
I need to download manual for keystone passport 2008 285rl
make sure battery disconnect is on not off make sure fuses are good in converter and blow out fridge LP system and hot water heater burners cob webs and make sure LP is on and LP detector is good
May 08, 2016 | Keystone 2008 Passport 285RL
How do l trouble shoot my propane system on my 2010 keystone cougar?
If checking for leaks, with propane system pressurized squirt soapy water solution on all lines fittings and connections, watch for bubbles and make repairs
The RV Doctor What the Pro Do Propane System
Jan 17, 2016 | RVs
Can a hitch be installed on a 2003 cougar
Best solution for you call an RV shop and ask them. Most hitch shops will tell you sure you can do it. But can you you really? Ask the people that sell these things for a living they will what you can or can`t install for a hitch and what you can haul with it. Hope this helps
Mar 08, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
Water runs for a second and slowly stops.
Isn't there a tap on your side that you might need to open ? (on the Outback's side of the hose?)
Jan 24, 2014 | Keystone 2010 Outback 286FK
Wiring diagram
0eaf58a4-fc80-49d8-8ec4-753d2bda9770.gifuse the flow chart . for fix it.
God bless you
Jul 11, 2013 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a keystone camper and apparently the hot water line under the belly is frozen because I get no water flow to the sink...funny thing is at the shower and bathroom sink the faucets are switched the...
YEP. I'M IN THE RV BIZ AND IT'S MORE COMMON THAN U THINK. SOME DEALERS DON'T DO A THOROUGH JOB OF DELIVERY INSPECTIONS. ANYWAY, TAKE A HAIR DRYER AND THAW OUT UR FROZEN WATER LINE. SWITCH AROUND THE OFFENDING WATER LINES, THERE SHOULD BE ENOUGH PIPE TO ACCOMPLISH THIS. ASSUMING THE LOW FLOW IS WHEN UR USING UR PUMP, YOU CAN TURN THE PHILLIPS SCREW ON THE HEAD OF THE PUMP CLOCKWISE TO GIVE IT A LONGER STROKE. CHECK THE SCREEN FILTER FOR ANY DEBRIS, KINKS IN THE LINE BETWEEN THE PUMP AND WATER TANK, MAKE SURE THE AERATOR SCREENS AT THE SINKS AREN'T PLUGGED.
Dec 04, 2009 | RTO Atwood Water Heater - 6 Gal LP
Recently purchased and did not come with owners manual and want to learn the trailers accomidations
You can order a Fleetwood Owner's Manual by sending a check or money order for $8.00 to the address listed below. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood Service & Training Center
PO BOX 1007
Decatur, IN 46733
May 25, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
