Question about Sony Televison & Video
Sony tv asked for software update.Since then tv switches on, coloured circles appear which move and then the tv switches off.Tried unplugging the tv, but once plugged back in it does the same thing.
SOURCE: hp officejet d135 series printer
Could be the printer carriage is binding, oil the rail and try again.
Posted on Nov 28, 2007
melnavz
  • 1226 Answers
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
jerryg50
  • 1689 Answers
SOURCE: KV-28CL10U colour circles
There are two things that commonly cause the fault that you are describing. Below is the main one.
It is very possible that the degaussing circuit or the degaussing coil is no longer working. A common fault is that the degaussing thermosistor has gone defective and the CRT has become magnetized. The earth's magnetic field along with other environmental things cause the CRT's internal mask to become magnetized over time.
The thermosistor in most Sony TV sets is located in the power supply area. It looks like a little black square box with 3 solder posts on it. In some models it has 2 solder posts. After a number of years this part may fail.
When the power is first turned on, the thermosistor is very conductive. After it heats up, it goes very high in resistance. It drives a high decaying AC mains current through the degausing coil (located around the shroud of the CRT assy) for about 50 to 60 ms. It then allows the current to decay to zero over the next 50 ms. When you turn on the TV set, you normaly hear a kind of a loud thump noise. This is the degaussing action.
Once the degausser is serviced and is working properly, it may take a number of power cycles to eventualy demagnetize the CRT. After shutting off the TV, it takes about 20 minutes before the degausser can work again. The thremosistor needs some time to cool down.
If you are not experience and trained for doing TV service, I would suggest you give the set out to an experienced TV service tech to change this part. There are serious safety issues when working inside of TV sets.
It is possible to purchase a manual hand held degaussing coil. There is a proper procedure for using this type of coil. If you were to manualy degausse your CRT, you would have to do it on an almost daily basis. The manual degaussing coil is fairly expensive to purchase. It would be better to service the set.
The second thing that causes the CRT to show colour purity problems (color splotches, or circles, or patches), is that the mask inside on the face of the tube has become dislodged off its supports or became warped. This can happen if the set has been dropped, or hit hard enough to do some damage to the mask. I have seen this where TV sets were roughly handled during moving them.
The only fix for a damaged CRT mask is to replace the CRT. The cost would be as much or more than the set is worth. This is if you can even find a replacement CRT. Most all of the manufactures no longer manufacture replacement CRT's for consumer products.
Only specialized CRT's are still being produced on a limited bases for specific industrial and military equipment that must still be kept in service. These are for some types of radar, medical, aerospace, and other related industries.
Jerry G.
Posted on Apr 16, 2008
teeNjay
  • 5 Answers
SOURCE: WS-55909 Mitsubishi Big Screen TV timer keeps blinking
it must be recording soething have u got IQ?
Posted on Dec 30, 2008
  • 4234 Answers
SOURCE: streaks and two black circles appeared on my screen
This is a hard one without seeing the actual defect. It sounds like there is a problem with the processing board. It could be as simple as a poor connection inside at a cable connection. The signal levels inside these sets is very low and any dirt or dust in the connection area can cause "noise" on the digital data lines that can show up in odd ways like you described. If the set is no longer under warranty, you can try reseating all of the cables and connectors inside the set. That may resolve the problem.
If not, try to post a picture of the screen here and I'll try to give you more options.
Dan
Posted on Apr 10, 2009
After initial set up and download, TV is displaying a hand on power plug picture with a red circle and line through it and a refresh symbol in light blue next to it, what does this mean?
Hi! and Welcome to Fixya!
What you have on the tv screen is a warning sign that your tv is currently updating its software. A hand holding a power plug with red circle on it says do not unplug the tv while its running the software update. The usual time for the update to finish is 60 minutes. It may took more than 60 minutes if you have a slow internet speed. This is normal especially if you are running the software update for the first time during the initial setup. The next time tv performs software updates it will take shorter time.
However, if the updates took more than two hours, the tv may be frozen. You can unplug and plug it back in and start from the initial setup again.
On some rare occasion, the tv may not proceed with the initial setup. You may have to turn off your modem to complete the initial setup. when initial setup is done, connect your tv to network and run software update again.
Let me know if you still have other questions.
Sep 07, 2015 | Sony BRAVIA KDL-55W802A 55" 3D 1080p...
My chrome cast screen is stuck showing the 100% sign with a circle moving around it
Sounds like it got stuck doing an update. Cycle the power on the chromecast. Unplug the chromecast and re plug it in.
Mar 09, 2014 | Google Chromecast
I installed the Ion VCR 2 PC converter and when I clicked VCR 2 PC to record, it says "the device is not avaliable, or is being used by another application" and will not let me use the machine. What do i...
1. Check in your Device Manager whether any Yellow coloured Circle with Black Exclamation is present, if yes then your driver is not installed properly.
2. See whether your device is recognised, If not try uninstalling the device driver and software and unplug the device. Restart the OS (do not connect the device), Install the Software and driver and after completion or if it asks to plug in the device, plug in the device and power on.
3. Still having the problem, check the latest updates or patches if required from the website, if nothing helps try it on another PC or reinstall OS in your PC.
Sep 11, 2010 | ION Audio VCR 2 PC USB VHS Video to...
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
PS3 blackscreen, but sound! tried all common tricks to reset!
Try your cable connections..either its not conencting properly to the back of your tv. or your cord is fried. Try a different tv and see if it works, if it does, it may be the connectors on your TV.
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Sonyk750
when you switch on your sony k750 a white color appear on screen an blinks and turn off..? if does, your phone software needs to be updated.
You can download your software through this link..
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/k750i?cc=ph&lc=en
Read the instruction before you download. after you install the software to your computer make sure that your phone battery is in full charge when updating your phone.
Sep 25, 2008 | Sony Ericsson K750i Cellular Phone
Screen Colours incorrect
Your CRT (Picture Tube) screen mask has become magnetized. You need to degauss the CRT. Have you moved you TV lately or at any point had speaker sitting next to it? These are two things that can magnetize the screen mask. Well in any event you will need what is called a degaussing coil to demagnetize the CRT.
Here is the degaussing procedure:
Standing about 10 feet from the TV Screen turn on the degaussing coil which is in a vertical position and rotate it in a circular motion walking towards the TV .
Once about .5 to 1 inch from the TV continue to rotate the degaussing coil and the move away from the TV while still rotating the coil.
Once at the point where you began, position  the coil to a horizontal plane and quickly move the coil back about two feet and the turn the coil off.
This will deguass the CRT.
Thank you,
Shuttle83
Oct 30, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
