Question about Sharp Microwave Ovens
Sharp microwave oven stopped getting hot, I followed steps to come off demo mode, what should I do next? Screen faded so can't read next step. It now starts for one sec an stops. Not sure what now?
It now starts for one second stops and beepsa few times
  • William Miller
    William Miller May 06, 2017
    What is the full model number as shown on the tag?
    I do display repair too, by the way. See below.
    William E. Miller, AS-EET
    pupista@gmail.comhttp://www.microwavecontrol.com
    Microwave Oven Control Panel Repair Nationwide
    "Recycling by repairing since 1982"
MicrowaveSvc
  • 9047 Answers
SOURCE: pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
Posted on May 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1870 stops at 59 seconds
Wow. I just read something ridiculous!
Well, never mind that, here's your solution:
This is a common problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 29, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Posted on Feb 09, 2009
Sharp microwave R-410LK fan and light do not turn off.
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Oct 23, 2013 | Sharp R-410 Microwave Oven
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
How do I get out of the demo mode
Hi Karen,
To get out of the demo mode you have to press the following buttons.
First press "Function"
Then "0"
then "2"
This should get you out of the demo mode.
Atul
Mar 13, 2011 | Panasonic NN-P794SF Microwave Oven
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Oct 17, 2009 | Sharp R-540DK Microwave Oven
Is in demo mode and I can't get out of it
I am familiar with TV sets being stuck in demo mode, but I've never heard of a microwave doing this. The fix for this on a TV is usually pushing a combination of buttons at the same time.
Call Sears or Best Buy and talk to an appliance salesman, or call a repair service. They surely wouldn't charge you anything for giving out this info.
Oct 09, 2009 | Sharp R-1480 Microwave Oven
How do you work an amana microwave? CANNOT GET OUT OF DEMO MODE WE WERE NOT GIVEN MANUALS
press the CONTROL-SETUP button on the pad and follow the screen prompts to get out of demo mode,also its in your user manual
Oct 04, 2009 | Microwave Ovens
Sharp R8310
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
Info on ordering Sharp UK parts / spares is here.
May 11, 2009 | Sharp R-1210 Microwave Oven
Feb 09, 2009 | Sharp R-540DK Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
18 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
