Question about Brother Sewing Machines
I JUST RECEIVED A BROTHER CX155LA, GOT IT THREADED AND IT WONT SEW A STITCH- KEEP GETTING E2
  • Brother Master
  • 9,488 Answers
Search for:
Make Model E2 error
or check the owner's manual troubleshooting section
Posted on May 07, 2017
I get an E2 error on my Brother CP7500 and the button lever is all the way up
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operation
    One beep is sounded.
  • If an incorrect operation is performed
    Two or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangled
    The sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew.
reference: http://support.brother.com/g/b/faqend.aspx?c=us_ot&lang=en&prod=hf_es2000teus&faqid=faqh00000059_000
user guide:
http://download.brother.com/welcome/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
quick reference guide:
http://download.brother.com/welcome/doch000566/bc21es20ce50qg02enfresdeitnlru.pdf
Dec 15, 2014 | Brother CP7500 Sewing Machine
Singer 503a
Adjust bottom tension !
Aug 25, 2014 | Sewing Machines
Why do I keep getting a F4 reading
Make sure the foot control is plugged in correctly. Make sure you have your foot off of the foot control when starting machine.
May 03, 2014 | Brother CS-6000i CS6000i 60-Stitch...
I just bought a brand new Brother XL 2600I and it was working great for the first day , next morning i change the thread to actually sew not just test strips . I keep getting bunches of thread or if i
Most likely your top thread is not threaded correctly. Unthread and rethread. Check with your manual to make sure you have threaded correctly. Thread bunching up on bottom indicates top thread is threaded wrongly.
Mar 05, 2014 | Brother XL-2600I
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
Sep 21, 2012 | Sewing Machines
Poor stitch on underneath when sewing on material
Re-thread the machine with the presser foot up and see if this improves the stitching.
When a sewing machine is threaded with the foot down, the thread cannot properly enter the tension control and then when you begin to sew, then tension cannot control the flow of thread as it is designed to do.
Refer to the manual and do the routine maintenance as recommended and this will help keep the machine working as it should.
Mar 06, 2010 | Brother XL-2230 Mechanical Sewing Machine
Just want to sew
Is there thread on the bobbin spool that goes on under the area where the needle goes up and down? This can be accessed by opening a drawer like compartment at the bottom left of the sewing machine. You need both the bobbin thread from under and the thread in the needle from the top to get a secure stitch.
May 08, 2007 | Brother XL-3510 Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
