Question about Panasonic Video Cameras
Panasonic RX-ES30 tape slow record how to fixed?
5 Suggested Answers
  • 136 Answers
SOURCE: how to pre-set radio stations panasonic radio/cd/tape recorder
the best thing would to go to the panasonic web site and they should have the solution. they might even have the manual for it. without a picture this is the best i can do.
Posted on Apr 01, 2009
  • 4234 Answers
SOURCE: My Panasonic DMR-ES30 DVD Recorder / VCR Combo is
This is a good sign that the power supply is having a problem. In standby or even on without a tape or disc, the current draw is low. Once a disc or tape is inserted there is a higher demand on the power supply. This is usually some defective capacitors that are easily replaced. Realize that there are other possibilities as well, but the power supply is the most common. The parts cost is in the $15 range.
Dan
Posted on Apr 28, 2010
SOURCE: IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Posted on Sep 09, 2010
HansPP
  • 2510 Answers
SOURCE: I own a Panasonic RX-ES20
The tape speed in governed by the capstan and the pinch roller - a thin silver pin and a rubber wheel about 3/4" in diameter. If the tape is not caught between the two, it will run at about the speed of the reels - fast, Check that the pinch roller moves up to the capstan pin when you select play. If it does not, there may be some tape jamming it or the arm may be bent or dislodged.
Posted on May 17, 2011
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
My Panasonic DMR-ES30 DVD Recorder / VCR Combo is about 5 years old now its fine on stand by but when i put a dvd or vhs in after about 10 seconds it cuts out completly any solutions on how to fix it...
Dan
Apr 28, 2010 | Panasonic DMR-ES30 DVD Recorder/VCR
I have a Panasonic DVD Recorder DMR-ES30VEB could you please tell me if this will still be able to record if I buy a new Panasonic digital TV??
Yes, connect to AV2 and you can select the output for AV2 from the menu.
Most tv's send a selectable signal out through av2 but if you match to your Panasonic, you may find it will automatically set up with the dvd recorder(like Sony Smartlink)
You simply go into the menu, select the av2 output set up and pick what you want to record. I.E. dvt, av1 etc.
Sep 04, 2009 | Panasonic DMR-ES30 DVD Recorder/VCR
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
How to pre-set radio stations panasonic radio/cd/tape recorder
Mar 27, 2009 | Panasonic Audio Players & Recorders
IT PLAYS TAPES SLOW
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Video Cameras Logo
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
