Question about Drills
How to use a vermount american #17192 drill press
Which step down transformer should I get in order to use the USA dyson dc39 in Aus? Do I need to just get the step down from 240v to 120v or need the isolated 1500w step down?
To use an American Dyson in Australia you need a step up to 240v from the American 120v. Better to but a European machine that is the right voltage already.
Mar 18, 2014 | Drills
How to attach drill chuck
Check for an allen bolt. Open chuck all the way and look inside for an allen bolt some drill presse have gone to this method of attaching the chuck. Hope this helps.
Jan 10, 2014 | Drills
I have a Chinese bench drill bought in Australia. The chuck was not attached at purchase. Looking at (American) videos on removal/attachment of chuck, the tapered spindle is part of the chuck. On mine, it...
open the chuck full open and check to see if theres a screw holding that taper in place inside the chuck. maybe you can figure it out from there.
May 23, 2017 | Drills
VERMOUNT CASTINGS HONEYWELL REMOTE RT8220A 1032
That link was not posted correct. Try this one to view the honeywell Remote:
http://www.ibuyfireplaceparts.com/20002047-transmitter-honeywell-remote.html
Jan 31, 2012 | Televison & Video
Hi, I want to replace an old American Standard toilet bowl that is a 4 bolt tie down design to the floor. Can I replace this with a standard 2 bolt floor mount design? If not are 4 bolt tie down models...
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
May 18, 2011 | American Standard 2294.011.020 Afwall...
How do I use a Vermont American #17192 Drill Press Stand? Anyone have an instruction sheet for this? I acquired one from a sale but am unable to figure out how to mount our drill onto it. Thanks.
Here you will see how the drill is mounted in the device. Position (b) around the handle and tighten it up untill drill seats firmly in place. Take a speed square, or normal square and eyeball or measure the drill to see if its straight. Use the alignment adjustment (A) to fine tune the drill to get the drill bit straight and square. Tighten up all the nuts holding drill in device and recheck the drill bit for straightness.. Put your work under the drill, press the trigger and lock into place to get the drill to constantly run without finger on trigger, pull down the press lever to drill your hole... Hope this helps!
Nov 02, 2010 | Drills
The bolt is bent and needs ti be replaced. Can i buy a new bold
Hi
You can buy a replacement at any decent hardware store like ACE,even HomeDepot or Lowes.Take whatever you have with you and remember that it's almost certain to be a metric screw.Sears stopped buying American decades ago.
If this helps,would you rate my post?
Bob
Aug 06, 2010 | Craftsman 4" Drill Press Vise, Side -...
I HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Jun 20, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
96 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
