Question about Whirlpool Washing Machines
Whirlpool aws 3551 fault FO7 - Whirlpool Washing Machines
    Brigadier General:
  • 8,619 Answers
Hi
Fault F07 is a Motor Control Unit Error. It means that the Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. To resolve this issue you need to:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
  • Please revert for further assistance.
    Thanks
    Rylee
    Posted on Jul 25, 2009
    AWO 3551 have a FP fault . help
    thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
    Feb 21, 2012 | Whirlpool Washing Machines
    Have a whirlpool AWO 3551 washing machine. Door locked light flashes and machine stops at random points in the program. Pump works OK and drains water. Don't suspect door lock module as washer works on...
    My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
    Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
    Fo7 error message whats it mean
    If you have anymore questions please feel free to ask, Rich.
    Jan 20, 2011 | Whirlpool GHW9400 Front Load Washer
    Tricity bendix aw 1001 w is not draining,pump and
    If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
    Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
    I changed the pump on my Whirlpool washing machine model AWO 3551 but it's still not pumping water. None of the hoses are bocked. What am I missing?
    Are you sure the pump is getting a supply to it?
    Also, the pump iself could be faulty.
    Only way to be sure, is test the pump on a drain cycle, and see if you can hear it going, or test with a meter for voltage. BE CAREFUL
    Mar 29, 2010 | Whirlpool Washing Machines
    Awful noise won't rinse wash or spin, on my whirlpool washer
    http://www.youtube.com/watch?v=WLPGs2UMUJc
    This video will show how to replace the direct drive coupling that runs the transmission.
    Jul 05, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
    How do i solve fault on hotpoint tumbale dryer fault code is fo7
    Have you checked to see if there are any blockages if so try to unplug it at the wall then back in try another programming cycle see if that helps
    Nov 05, 2008 | Hotpoint Dryers
    Envelopes
    you sure you have the model correct???
    as far as I know Sharp DM-3551 is multi-task machine but, it is not capable of printing envelops.
    Oct 17, 2008 | Sharp DM-3551 All-In-One Printer
    How do i clean the pump on my whirlpoll awo 3551
    Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
    Jan 25, 2018 | Washing Machines
    Washing Machines Logo
    238 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
