Question about Jabra Radio Communications
How do you turn jabra bluetooth silent mode off , i have no sound even though it is pared and connected, i can hear thr bluetooth voice tho
  • 5 Answers
SOURCE: How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Posted on Nov 01, 2007
SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
Posted on May 20, 2008
SOURCE: Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Posted on Dec 17, 2008
SOURCE: voice command turn off?
Voice command is activated by the side button that is alone (right side if your facing the phone's screen) when the phone is closed. I don't know how to prevent the phone from doing that, but I do know how to make sure the phone does not say "Please say a command."
Menu
Settings and Tools (Far right icon)
Tools (#2 on the list)
Voice Commands (#1 on the list)
Hit settings, which is going to be the right bumper button (above the CLR key)
Go to prompts (#5 on the list)
Mode (#1 on the list)
It will be currently set on prompts, which is why it says "Please say a command." You can either set it to readout or tones only. Tones produces a short beep. Readouts only displays text (no noises). Being that you have your phone on silent, I assume you want readouts.
That will at least prevent stop the phone from making random statements in your pocket. Hope this helps.
Posted on May 01, 2009
SOURCE: How to get Jabra BT2050 in pairing mode?
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Posted on Jan 10, 2010
Testimonial: "It worked."
HOW TO CHANGE LANGUAGE ON JABRA MINI BLUETOOTH
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Oct 12, 2016 | Jabra Solemate Mini Portable Bluetooth...
Auto connect/disconnect
Hi. To turn Voice Guidance off, press the Option button. To find the settings, press up or down slowly until you hear a beep. Press OK to enter the voice guidance menu. From that his menu: Voice Guidance On/Off: Use arrow keys on remote to toggle on and off. NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
Jun 14, 2013 | Jabra Extreme2 Bluetooth Headset
Paring bluetooth
make sure that your jabra is in pairing mode then go to the bluetooth menu of your pc. select add device and wait until your computer finds the headset
May 11, 2013 | Radio Communications
Connection
Begin with your headset turned off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and make the application proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise, just press the answer/end button, and the link should be done again. In this case, it might be prudent to place the headset in your ear and check if the voice channel has been actevated (you can actually hear it). If so, either press the answer/end button again, or turn your phone off (i.e. just put it in stand-by), and make sure the voice channel has been cut off. The bluetooth connection will still be in stand-by.
Hope you are able to sort your problems out.
Cheers! Carlos
May 28, 2010 | Jabra BT350 Bluetooth Headset Headset
Palm Treo and Jabra bluetooth headset
Turn your headset off. Then, press and hold the answer/end button until the indicator light is solid lit in blue. It is in paring mode. Now, make your phone's bluetooth application search for new devices. After a while, the BT-350 should appear on-screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing proces is successful, the headset should enter stand-by mode. The pairing process is timed.If you fail to complete it, you'll have to start it over, from the phone turned off phase. Once paired, whenever both your headset and your phone's bluetooth radios are turned on, they should connect to each other automatically. Otherwise
Hop
May 16, 2010 | Jabra BT350 Bluetooth Headset Headset
Discovery mode
Cheers! Carlos
May 12, 2010 | Jabra BT350 Bluetooth Headset Headset
Discovery mode
If you mean pairing, then hold the button down until both red & blue lights flash. If your bluetooth transmitter is in paring mode too, it will connect up. Note that the headset must be off before you begin.
Mar 20, 2010 | Jabra BT350 Bluetooth Headset Headset
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
How do I get my Jabra VBT185Z into pairing mode?
Turn on paring by pressing and holding center (blue button) until LED is solid blue.
Headset goes into pairing mode (unless already paired). Set your phone t "discover Jabra VBT185Z."
Enter PIN, "0000"
Good Luck!
Jan 02, 2010 | Jabra VBT185Z Bluetooth Headset
Radio Communications Logo
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
