Replace timer control knob on LA8800xtno washer
shaggyrat
  • 1224 Answers
SOURCE: How can I replace a damaged timer control knob?
i was reading up on this item and i came across section where they mentioned you have to purchase 4 complete different replacement knob boxes or panels
heres the link boy this product is having one heck of time
http://www.reviewcentre.com/reviews105062.html
Posted on May 09, 2008
  • 958 Answers
SOURCE: Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Posted on Aug 02, 2008
SOURCE: timer replacement
the knob, actually, unscrews. pull out the knob as if you are starting a wash cycle, and use needle-nose pliers to hold the back, and unscrew. i learned the hard way when i pulled on it like it was one of the other knobs and yanked the post out.
Posted on Dec 02, 2008
  • 1214 Answers
SOURCE: kenmore washer 110.92292100..Washer Timer Control Knob is broken,
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Posted on Feb 03, 2009
  • 107 Answers
SOURCE: Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Posted on Mar 13, 2009
Need new cycle control knob for Whirlpool Model LLR8233BNO
You can order replacement parts online. Here is a site that I have used in the past.
http://www.appliancepartspros.com/top-cabinet-parts-for-whirlpool-llr8233bn0.html
There is a place to search within this model and if you type "knob" without the quotes, it will show you just the knobs for the washer.
Oct 18, 2013 | Whirlpool 3362624 Washer Control Timer...
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
How do you access the control panel the knob that sets the wash cycles is broken and needs replaced
The topside control panel has four small torx screws that hold the control panel to the rear. The timer has a small U clip under the knob that needs to be removed with needle nose and then the knob comes off so the timer can be replaced. I have your washer's training manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 20, 2010 | GE WJSR2070B Top Load Washer
GE WASHER MODEL #WBSR3140G0WW: TEETH ON CONTROL
I suspect that a mounting tab has broken off the timer. Take the four torx head screws off the back edge of the top of the washer and open up the backsplash to confirm this. I manufacture a make shift Z shaped metal part to hold the timer in place without having to replace the timer.
Mar 25, 2010 | General Electric WBSR3140GWW Top Load...
Kenmore washer Model # 110.26852504 Cycle control knob?
You gotta pull out a rod behind the timer and that releases the knob.351bd46.jpg The rod when pushed into the timer spreads the shaft and holds it on there. To get to the innards you gotta flip up the controls. I have a cool video that shows how
Mar 12, 2010 | Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Im replacing the timer on a whirlpool washer . how does the knob come off?
Quick and easy... I'm guessing you've already got the control panel taken apart so you can see the back of the timer. Just take out the black piece that holds the timer and knob together and attach the new timer replacing the wire mount and black knob
Apr 08, 2009 | Whirlpool LSR5132PQ Top Load Washer
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Mar 02, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer 110.92292100..Washer Timer Control Knob is broken, just spins around..don't know how to get it off to replace it. Need a replacement part. Called a repair man, he wants $75.00 just to come...
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
