F-05 code showing, what does this mean? - Washing Machines
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
My washing machine shows F-05
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Hi, the above web page shows fault codes and what they mean for Hotpoint machines
Mar 02, 2011 | Hotpoint Washing Machines
I have 05 Wideglide and i have alot of codes showing and need to know what hey mean 60563,61121,61122,u 1097,68921-01c,61006,61007,67033-04a
Hi Lankey3, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 24, 2011 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Wd860 showing error F-05. What does this mean?
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Apr 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error f0-05 showing during cycle
Error code F05 means water level switch is stuck on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Refit and test.
Mar 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Code P0174 05 Corolla
I don't show any po174 for an 05 corolla. But I do show a po741, if thats the code you're getting.
It means theres a problem with the torque converter
clutch system. It could be the tcc solenoid. Either way, it's related to what you just had done.
Good luck.
Feb 01, 2010 | 2005 Toyota Corolla
Error Code E-05?
Error code )% i think means no focus, you could try cleaning the laser, but otherwise its a replacement laser :(
Regards
Mark
Jan 18, 2008 | Kenwood KDC-MP4032 CD Player
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
