Question about Photography
My shaft came apart. how do I reassemble by the collar in shaft. doesnt want to push back together
Minnkota maxxum 80
  • Photography Master
  • 5,046 Answers
One almost hesitates to enquire, but shaft for what ? If you can tell us the make and model of the camera involved, we will do our best to assist.
Posted on May 06, 2017
Service slr lens
Unless you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens, don't do it yourself. Take it to a camera shop and have a properly trained and equipped professional do it.
Jan 07, 2014 | Tokina Zoom Telephoto AF 80-400mm...
Replace the u joints and carrier bearings for a 92 GMC Sonoma and now has a vibrations
When you removed the drive shaft, did you properly mark the shaft where it comes apart at the carrier bearing? This joint telescopes and usually must be separated to get the carrier bearing on/off. If you reassemble the shaft 180 degrees out (most shafts can go back together two ways), you will throw the driveshaft out of balance. The vibrations will be felt from almost the instant you start moving. You will need to drop the shaft and reassemble the shaft back to its original position.
Dec 20, 2013 | Cars & Trucks
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
I have a minnkota maxxum 74lb thrust trolling motor. The pedal pin in the foot control keeps sliding out on one side and I have to push this back in to stabilize the pedal. Is there something...
Good day ,
The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in.
if so put a little lock tight on the pin and push it back in it should hold again
good luck
Gordy
Nov 03, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Looking for parts brakesdown minnkota 101
Google the Make and model...dozens of web sites, including MinnKota,
Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Rear Axle Seal Replacement
remove rear tires, then remove brake calipers and rotors, then remove the 4 nuts (each side) that hold the axle shafts to the axle tube (located around the axle tube behind the backing plate) then using a slide hammer pull the axle shafts out, next using a die grinder and an air hammer get he retainer collar and the bearing off (without damaging the axle shaft) then remove the seal and the outer race which will still be in the housing. next put it all back together, make sure the plate with the studs is still on then slide the seal, bearing, then retainer on (all new parts) and using a press push them all the way back on. then is simple reassembly.
Apr 21, 2009 | 2004 Jeep Grand Cherokee
Photography Logo
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
