SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
SOURCE: I have a small bunker hill digital floor safe. I
follow the following link: http://www.harborfreight.com/manuals/91000-91999/91006.pdf you will see a picture of the bunkerhill digital floor safe, ITEM 91006-6VGA, under the sale price, you will see in GREEN "download product manual. There you will find the instructions for this safe. It took me about 30 minutes to find, then realized I didn't have batteries inside. Lucky for me, I found the key. You will need batteries inside. Otherwise, call the company Monday-Friday 9:00am - 7:30pm EST at 1-800-444-3353 (toll free). For Technical information call Monday-Friday 9:00am - 4:30pm EST at 1-888-299-3427.
SOURCE: My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
SOURCE: Bunker hill digital security wall safe no key. No combination. Was here when I bought the house
Try a locksmith first. You may end up having to destroy the key lock to get it open.
1-800-444-3353. They are distributed by Harbor Freight. This may be their phone number. In any case, they have technical info.
http://manuals.harborfreight.com/manuals/45000-45999/45891.pdf
This is the manual.
Gary
