Question about Refrigerators
ARE THE WATER PUMP FOR ICE AND WATER DISPENSER UNIVERSAL WITH OTHER BRANDS
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
  • 489 Answers
SOURCE: water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Posted on Apr 27, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Gss23qgta bb
Check water cut off then check your water line it may have a kink in it the next thing would be the pump for the water on the back of the frig if you have water dispenser and ice you have two sided pump just because you are getting water does not mean the water is going to the ice compartment. Also unplug and plug your ice maker this may reset it wait 24 hours it can take that long to start working again. .
Apr 27, 2014 | GE Refrigerators
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
I just bought the Whirlpool 6th sense refrigerator 25.6 cu with water and ice dispenser. However, I am in a place where I cannot connect to water supply because of quality issues. How do I fill in the...
you have to have water pressure to get water and ice you could get a tank and pump to put your drinking water in or get a good filter for your low quality water
Oct 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water/ice dispenser does not work
Your switch is probably out. No biggie. Just call us with the brand and model number and we will get the part to you! Hope this helps and we look forward to working with you! :>)! Ella
Aug 25, 2009 | Refrigerators
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
