Question about GPS
I have a clicking sound on my akg c 5 18 when I tap the top, it is there when I hit the Tom too, what could be causing this
Surha AKG uhf ht 40 handheld mic
You need a pop filter while recording. There are different reasons why a "pop" would get recorded in the signal. Either because of the harsh P's and T's while singing or rapping like "Business", "Pain", "Property", etc. or it could be jitter problem due to an unstable clock. Mostly you would recognize these ones cause they don't sound like the pops coming out o a persons mouth. They're more like clicks. Your problem, from what I understand is due to the former reason. That's why you will need a pop filter.
Jul 06, 2014 | AKG Audio Players & Recorders
Trouble with three SM57 having low volume unless directly on sound source
It is unlikely there is anything wrong wit the mics. The SM57 is very simple. Literally just a magnet and coil of wire. The problem that you describe is likely caused by your mixer, the presonus, etc.
Oct 29, 2012 | Shure SM57-LC Professional Microphone
If i hit the ride bell, the tom 3 sound will come out also if i hit the crash bell, the tom 1 sound will come out also any idea how to fix it? many thanks
Is the 9ch snake cable correctly connected? TOM 3 should be plugged into the 4th input and TOM 1 should be plugged into the 2nd input. (1- SNARE, 2 -TOM, 3 -TOM, 4-TOM, 5-RIDE, 6-CRASH.........)
Jul 22, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
No sound is coming out of the right side of my AKG K 518 LE
If you click my user name you will find a tip about headphones that might be able to help you.
Apr 01, 2011 | AKG K 240 Studio Professional Headphones
My tom tom one has lost its voice
From the main menu tap preferences.
To change the volume, tap Volume preferences in the Preferences menu. You will probably see a little "speaker" icon with an X through it. Tap this to turn the sound back on.
To change the volume quickly while you are driving, tap the bottom left-hand section of the Driving View and move the slider.
To change the voice, tap Change Voice in the Preferences menu.
Jan 27, 2009 | Tomtom ONE GPS Receiver
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
MY TOMTOM ONE DOES NOT GIVE ME SPOKEN STREET NAMES AS THIS MODEL SHOULD,CAN U GUIDE ME THE SETTINGS
These steps are for my TomTom One (2008) model.
1. Once you have turned on your TomTom tap the screen.
2. Tap 'Change preferences'
3. Tap the arrow to get to page 2 of Preferences
4. Tap 'Change voice'
5. Tap arrows until you get a computer voice - I chose Samantha.
6. Tap the 'Select' button to the right of the voice picture.
7. This screen is labelled 'Speech preferences' and the first one is 'Read aloud street names'
8. Tap the box to the right to select this preference.
Good luck.
Sep 12, 2008 | Tomtom GPS
Tom Tom One
get to the navigation screen and tap the screen, there should be a spanner icon, which is the change preferences icon, tap this, click on the arrow three times until you come to a screen with flags on it, you should be able to select english Uk from the screen
Dec 30, 2007 | Tomtom ONE GPS Receiver
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
