Heater does not turn on
When plugged in heater does not turn on. I don't hear the normal beep when plugged in.
All sound geting a long beep
Hearing a 'beep' is usually to warn you there is a fault. I do not know a single long beep as a code for your Notebook. Turn it on and do not touch anything, and see if there are any short beeps and/or other long beeps, and let us know
Quite often it is a fan problem, can you hear your fan running and does it sound normal?
Feb 10, 2014 | IBM ThinkPad A31 Notebook
Hello just been given a ps3 you plug it in turn it on and nothing comes up on telle you take the lead out the tele and it says power supply lost plug it back in but still nothing. also it wont turn off on...
u could try resetting ur ps3 by holding down the power button on the front panel for 5seconds/u should hear one beep then a second beep/ps3 should revert back to normal av output.
Oct 14, 2013 | Sony Playstation 3 (PS3) Console
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
My ibm thinkpad won't turn on
Try powering on laptop what happens do you hear any beeps or see any lights normally if u see lights this is a sign that it is working if not your motherboard could be bad if you see lights and hear constant short beeps this means your memory can be bad, Try powering on laptop without battery and only power supply plugged in.
Sep 05, 2011 | IBM ThinkPad T30 2366 Notebook
On boot up I can hear the hard drive responding but I dont hear the computer posting and the screen is black.. no errors or anything. Any suggestions?
Reseat the memory and try it again. If it still doesn't work, what do you hear for the hard drive? Does it just whir to a full spin up, or does it chunk n klunk?
Jul 06, 2011 | Toshiba Satellite L305D Notebook
When i turn on my ps3 it turns pitch black using hdmi and and normal output. it has a green light as well it just is pitch black on the screen.
The problem could be that the video output settings don't go through the correct video cables. Here's how to reset those settings:
  • Hold down the power button for 5-10 seconds until you hear two beeps; then let go.
May 31, 2011 | Sony Playstation 3 (PS3) Console
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Aircondition not working
E1 indicates  Filter needs replacing/Cleaning , this code flashes after 720 hours of operation time.
Disconnect the power plug
Clean or replace filter
HOLD DOWN (dont let go) Of  the ON/OFF button and plug the unit back up and continue to hold the ON/OFF button until you hear a beep
After the beep unplug your A/C
Then plug it back up to and turn it on for normal operation
IF THIS FAILS TO REMOVE THE CODE
UNPLUG A/C  THEN HOLD DOWN THE MODE BUTTON AND PLUG IT UP STILL HOLDING THE MODE BUTTON UNTIL YOU HEAR A BEEP.
UNPLUG UNIT  AND THEN PLUG IT BACK UP AND ONE OF THESE 2 STEPS WILL FIX YOUR PROBLEM   UNLESS THERE IS A MAJOR PROBLEM IN THE CONTROL BOARDS
Oct 13, 2007 | Sharp AFS60FX Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
