Question about Honda Garden
Honda harmony mini tiller gx31 has no spark. does it have points or why no spark. I put on a new carburator and new spark plug. Thank you
  • Honda Master
  • 4,300 Answers
If it was produced in the last three decades it is almost certain to have electronic ignition, probably from a self contained ignition module.
It isn't possible to check very much other than to ensure the flywheel magnet is still powerful, the air gap is not excessive, that any ground connection is clean and secure and the wiring to the engine stop is not short-circuited. If a resistor-type suppressor spark plug cap is fitted it should be checked for continuity.
If all is in order the module should be replaced...
Posted on May 06, 2017
  • Vernon Taylor May 06, 2017
    As an afterthought, Honda and other engines tend to be fitted with a low oil sensor that will prevent engine damage by cutting the spark and stopping the engine. It would be wise to temporarily disconnect it and test it.
Honda 25 cc 4 cycle mini tiller how to adjust carburator
With one screw you can adjust the idle speed, and with the second, located under the carburetor you can adjust the running or load speed.
Mar 22, 2013 | Honda 25cc 4-cycle Mini Tiller
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay.
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
2-cycle gas mini tiller
check the spark plug. take the spark plug out and put just a dab of gas where it goes and put it back in then try starting it. i have the same problem with mine
Jun 29, 2012 | Craftsman Garden
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
I have a Troybilt weedeater that works great until I put the tiller attachment on. With the tiller on, it dies after a few minutes of use. Any ideas?
Hello dane. Change the fuel filter, install a new spark plug and a new air filter. Then get a can of carburator cleaner to add to your fuel. let that treated fuel run for 5 minutes and you should have your problem solved. If not, you will have to replace the carburator or rebuild it.
Thanks for choosing Fixya!
Mar 21, 2011 | Troy Garden
Honda 4 cycle cult wont start. New gas primer primes new spark plug. Won't fire.
Check the start switch and the start switch line. If not broken, check the choke switch and try different settings to start it. Last check the gas line for any cracks. This tiller can be easily be flooded when pushing the prime button..
Jun 25, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
I'm looking for an online maunel for my Harmony FG 100 mini tiller.
You can download (free) or purchase an OM containing a small parts list here (yours is a mini tiller):
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Mar 14, 2010 | Honda Garden
Tiller won't start.
I recently had the same issue with a tiller that hadn't been started in over 8 years. Turns out that old gas had left a varnish coating in the carburator keeping the gas from feeding. Rebuilt the carburator with new float, needle valves and bowl, new Welsh plug. Fresh gas and two pulls later it went to churning. Took a short time to adjust the two needle valves for idle and full throttle and we went a-tilling.
Apr 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Mar 16, 2009 | Honda 25cc 4-cycle Mini Tiller
Garden Logo
48 people viewed this question
Top Honda Garden Experts
John Trevino
Are you a Honda Garden Expert? Answer questions, earn points and help others
