Hello, I have a nobo electric wall heater Any help please
Hello, I have a nobo electric wall heater. I actually have 2 . One always works. The other sometimes when switched on lights the red on button yet does not heat. I have never set it to any setting. I have tried to press the reset in case it has set its self somehow yet nothing happens. Any help please
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
hotuna
  • 288 Answers
SOURCE: Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Posted on Mar 05, 2008
roniecon
  • 6927 Answers
SOURCE: haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Posted on Jul 03, 2009
SOURCE: need manual for swan steam generater iron model s15040
you have probably solved this by now but
I just got the same model new
switch on instructions as follows
press and HOLD the POWER button for 3 seconds to switch the unit on
once temperature has been reached, press and HOLD the steam button on top of the iron for up to 20 seconds
this will prime the steam pump and only has to be done once for each ironing session
the pump noise will stop once it has been primed with water
hope this helps if still needed
if you need the user guide, let me know, I'll scan it for you
Wendy
Posted on Jul 05, 2009
SOURCE: nobo heater
the nobo heater cant keep opening for long time, i just turn it on then secound its turn off by self, i dont know if there have time contorl or not? the one im sure its not broken , just dont know how to fix this out,please help.thanks!
Posted on Oct 20, 2010
2YV14 need to find a new replacement fan blade and hub for a dayton wall heater model #2YV14
Hello Jeffrey Messenger,
Dayton is a big name product available at GRAINGER.
Electric Wall Furnace,
Recessed or Surface, 240VAC, Watts 9200
Replacement Parts
H
elp finding replacement parts?
Please call 1-800-GRAINGER
(1-800-472-4643)
The 2yv14 is a well known heater... sadly it has been
MANY years since I have purchased any
Dayton equipment... but GRAINGER RETAIL
OUTLETS WERE The reliable PLACE TO GO.
(see below).
GRAINGER
https://www.grainger.com/category/dayton/ecatalog/N-1z13ntg
DAYTON-Electric-Wall-Furnace-2YV14
Electric Wall Furnace Recessed or Surface 240VAC Watts 9200
Carnac the Magnificent
Mar 22, 2017 | Dayton Heating & Cooling
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get instructions on how to replace and swap over for a new one?
There are not even photographs of the product online...
That tells me that nobo might be using generic timers made by various manufacturers.
And they might not use the same timer one year to the next... preferring to sell whatever they can buy with lowest price.
A lot of companies re-brand generic products and sell them under their brand name, and folks assume the company made the product.. and the company has manuals... but they don't manufacture anything... they just sell stuff.
First Alert, Timex, Kingshield, Stanley, ... are examples... I suggest not buying products from companies that do not post manuals
maybe you can find a manual by doing a google image search for timers, heater timers, or Nobo ... and seeing if you can find similar timer.
Nobo timer manual below is also sold under Sunlight and Timex brands.
http://www.e-tradecounter.co.uk/PDF/p-1125.pdf
Gene
Oct 08, 2014 | Hardware & Accessories
Nobo Heater - Power not constant
You do know that these kinds of heaters "cycle".?? They turn on and off, as a control regulator (thermostat) tells them to. You should have an adjustment that will control how frequently it cycles on and off... You should also have some kind of switch that shuts the heater down if it gets tipped over. However, I tend to assume you know most of this.. If it was simply "cycling", though, I'd think that there would still be some light on full-time to show it really was plugged in and working... So, if I had to bet my money, I'd bet that there's some built in safety switch inside that heats up and kicks the whole thing off quite soon after you start it going. I'd guess that by unplugging it, it eventually resets itself so that you can try it all over again. It could be one of those cases where it might be easier and cheaper to junk it and buy a new one.
Nov 14, 2013 | Heating & Cooling
Working instructions for creada electric wall heaters modle 79351S
sounds like the electric economy 7 heaters too me, i had them and hated em.
basically the heaters work between 1am-7am or similiar.
the best way is to think of it as a battery, it needs to be charged and the output is whatever your using the power on.
the higher the number on the input the more heat is stored into the heater. the higher the number on the output the more heat that is released.
i always put mine on 5 to store the most heat and left it on about 3 so it would always release and charge.
hope that helps
Oct 06, 2012 | Heating & Cooling
Hi, I have a NOBO heater: TYPE No. E4EU203 - 152AIX APP No. V04566 Problem - The heater has just stopped working. I have just taken the cover off and had a look at the electrinics and I have tested...
APP No. V04566
Hi - I had the same problem, rang the people I bought it from - they asked if I had disconnected it over summer - I had. Apparently you shouldn't disconnect, because battery needs to recharge - so now I have done that and it is slowly coming to life - give it half an hour or so.
Hope this is your problem - great heaters!!
Cheers
Gerda
Hope this helps
May 10, 2011 | Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get programming instructions or just how to get them to work? I have tried google but nothing yet ...
The instrusctions are available in english on the australian site: http://www.nobo.com.au/Brochures/Shared/NOBO%20Timer%20Operational%20Instructions.pdf
Other useful documents available here too.
Oct 16, 2010 | Heating & Cooling
Marley B2451 wall heater
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at http://www.qmarkmeh.com/
Doug
Jan 22, 2009 | Marley Electric Hydronic Baseboard Heater,...
Nobo heater
Feb 20, 2008 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
