Question about Cameras
My s8100 pop up flash won't stay locked down when not in use
3 Suggested Answers
kerguney
  • 575 Answers
SOURCE: How to lock the pop-up flash back down after using on Nikon 5700
In Auto mode it keeps come automatically when the power is on. .If you select other modes (i.e; P,A,M ) it does not but you need to pop it up manually. it stays as locked unless you do it manually.
If this does not help and If you need more info pls provide more details for additional solution..
Posted on May 04, 2010
  • 3 Answers
SOURCE: Canon S8100 battery won't charge
well somethings wrong with your canon S8100 battery or you need a new charger, or battery
Posted on Apr 24, 2012
My Nikon coolpix s8100 camera will not keep the sd card inside. It is not locking the card when I try to insert it.
Have you tried inserting it in the opposite direction, if the flash card's label faces left, turn it to face the right as it's designed to be inserted only one way. If this does not work, shine a flashlight into the cavity as a foreign object may have fallen inside.
Dec 22, 2013 | Nikon Coolpix S8100 Digital Camera
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
Apr 24, 2012 | Nikon S8100 Digital Camera
Nikon s8100 not recognised by usb
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer and Picasa.
Feb 03, 2012 | Nikon S8100 Digital Camera
How do I fix my Nikon COOLPIX S8100 flash
Check the camers's flash setting, make sure the flash has not been turned off.
Also check the batteries, make sure they are fully charged, a low charged battery will not charge up the flash capacitors.
Nov 17, 2011 | Cameras
Nikon coolpix s8100 lens error lens won't retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 07, 2011 | Nikon S8100 Digital Camera
My nikon s8100 won't turn on when I press the on button... but it will light up green when I plug it into the charger! help! :( I just got the camera!
It means it has a bad battery since it recognizes power using a different power source. Replace the battery and it should work fine.
May 10, 2011 | Nikon S8100 Digital Camera
May 04, 2010 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
48 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
