Question about Pool & Spa
I emptied the the hot tub, cleaned it and refilled. It wont restart. I've flipped the fuses and the controll board has ---- and that's it. Is there a restart button that I dont see.
  • 79 Answers
SOURCE: maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See for disassembly photos and other Neptune information.
Posted on Jul 05, 2008
SOURCE: Where is the drain on the Aruba Majestic Hot tub?
the drain is located on the very lower left corner of the tub. (lower left is decribed as where the control panel is at the top, look at the bottom to find the plug and insert a hose to keep the water flowing away from the tub.
Posted on Jan 10, 2010
SOURCE: Our hot tub uses a Waterway Pump. We emptied the
I have the same problem with one of my waterway pumps every time I drain my spa. It's an airlock that is fixed as follows. Remove any one of the three drain plugs in the outside plate of the wet end (preferably the lowest). Let the air out and replace the plug when water runs through. Now the pump will work. WARNING: if you run the pump dry with the airlock you can damage the shaft seal and the pump will leak water.
Posted on May 15, 2010
  • 310 Answers
SOURCE: just drained and refilled, plugged
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
Posted on Nov 23, 2010
SOURCE: keeps saying prime. I've unplugged and restarted, refilled resevoir.
I unplug the unit and it reset. The Prime light went off.
I unplugged mine and the unit reset and the Prime warning went off
Posted on Sep 16, 2012
Gecko blown heater fuse
check recirculation pump and heater element and temp sensor and pressure switch
Mar 10, 2018 | Pool & Spa
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
There is a symbol of ... flashing under my temperature. Not heating up but pump and everything else working
check to see if fuse is blown if you turned it on b4 full it could blow fuse or temp sensor also check heater element sounds like temp sensor not calling for heat
Apr 16, 2014 | Pool & Spa
Air lock for my aruba spa hot tub how do i fix it
This sounds like a problem with the circuit board inside the spa control box.Do this:
  • Turn the breaker off
  • Unplug everything that is plugged into the circuit board i.e. the pump, heater coil, air blower, light etc.
  • Turn the breaker back on
If the circuit board stays on then you have to go thru the process of plugging one item at a time turning the breaker on then off to find the part that is bad.
US Parts Center
Dec 19, 2012 | Pool & Spa
When I start the wash cycle, the hot water just barely drips into the tub. I've taken off the hose and the filters are clean. I've also removed and cleaned the tube that actually goes into the...
This is symptomatic of a malfunctioning water control valve- the hot water one. Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Self priming hot tub pump won't prime
If you have had the tub empty and refilled this could be an air lock and all you may need to do is open the drain valve till you get water out of it. Good luck
Aug 31, 2010 | Qca Spas Paradise Hot Tub
Where is the drain on the Aruba Majestic Hot tub? I have never drained the tub and would like to keep it empty for a few months before refilling
Oct 10, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
WE have an older outside model JACUCCI brand hot
Try hitting the reset button in the control box, and let me know if it fixes it it's red. And inside the timer control pannel.
Aug 06, 2009 | Home
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
