Question about John Deere Garden
My john deere x 340 spitts choke on carb moving upwards dies alot it has new plugs fuel filter air filter
  • John Deere Master
  • 7,515 Answers
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Posted on May 16, 2017
Mower only runs with choke held open
Have you cleaned filter on carb unit? My filer gets plugged with dry grass and does this. I have to remove filter and clean out grass even though the cover is on tight, don't know why but it does. Hopes this helps.
Sep 23, 2014 | John Deere Tractor Starter 285 345 2243...
John deer sabre acts like it starving for gas already check fuel filter
is the vent in the gas cap plugged?if it runs better with the choke on part of the way a jet in the carb might be plugged
May 13, 2012 | John Deere Garden
Jd X320 will not start changed fuel filte,spark plugs,and checked air filter
I assume it cranks, but won't fire up? Make sure the choke lever is moving the linkage in front of the carb. If so, tap the carb bowl lightly with a wrench. (That fixed mine once, and it never did it again) Have you had your valve lash adjusted? Be sure the carb is getting fuel. Pull the fuel line off the carb, and try to crank it... My X320 has 1,500hrs on it, and I have had great luck! Keep me posted, I want to help you get this figured out!
Oct 06, 2011 | John Deere Garden
I have a john deere gx85, i have been using it all year and had no issues until recently. it runs strong for about 5 minutes then all of a sudden dies and sounds like it chokes itself out. i cleaned air...
A buddy of mine had this problem. He said there is a line running from the carb down to the crankcase. I don't know if a valve quit working in the carb or what...basically after he shut it off, it was draining fuel into the crankcase. Obviously he changed the oil, and started shutting off the fuel valve after he mows with it. No problems since.
I imagine the problem could be solved with a carb rebuild as well.
Oct 21, 2010 | John Deere Garden
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
09 JD X 340 27hp Kawasaki eng\ surges
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 42 inch,17.5 hp-was running good then just died-will start back but will only run about a minute and die again,clean air filter,changed fuel filter,checked fuse -ok, module on side of engine...
have you had a look at carb side of things as it may be having fuel starvation probs.. the fuel in line not getting through jets or float chamber cleanly.. also the tank might have contamination from rust or debris..
Aug 13, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
