Can not get my tv to regognise fire stick on input
Setting up fireTV stick. It's plugged in to TV and power.ts Tried all inputs on TV. None worked. What am I doing wrong???
not sure if this link will help you out.
1. The easy way (5 mins)
  1. Plug your Amazon Fire TV Stick into your TV and plug the USB power cable into a spare USB port or use the power adapter.
  2. Go to Settings. ...
  3. Go back to the homescreen and install an app called Downloader - this will be listed under the Popular Fire TV apps section.
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
Oct 28, 2017 | Televison & Video
I have plugged my fire stick to the hdmi and power outlet, turned on the tv, but nothingness has appeared on tv and is not responding when I use the home button on voice remote? What shall I do?
Typically you need to be in video feed for the HDMI port. On the remote, the button is usually called video or input. Press that button to get to your HDMI port. Then you should should see the Amazon fire stick feed.
Oct 27, 2017 | Televison & Video
Can I get technical support on my firestick?
yes, here you go
Amazon.com Help: Amazon Fire TV Devices Help
https://www.amazon.com/gp/help/customer/display.html?nodeId=201729510
Your Amazon.comToday's DealsGift Cards & RegistrySellHelpDisability Customer Support · Help & Customer Service · Amazon Device Support > ...
Call U.S 1(844) (229) 2888 amazon fire stick techn... - The Spotify ...
https://community.spotify.com/t5/.../Call...fire-stick-technical-support/.../1904650 1 day ago - Call U.S 1(844) (229) 2888 amazon fire stick technical support number1(844)(229)2888 amazon fire stick support numberCall U.S 1(844) (229) ...
X-866)-391-8221 AmAzOn Fire StIck technical SUppor... - The Spotify ...
https://community.spotify.com/t5/.../X...Fire-StIck-technical-SUpport.../1901910 Y-866)-391-8221 AmAzOn Fire StIck technical SUpport phone number Amazon Fire Stick technialnumbe #@ OPT+IONSY-866)-391-8221 AmAzOn Fire StIck ...
[1866:316:6909] [Amazon Fire Stick Tech Support Number] - TechNet ...
https://social.technet.microsoft.com > Wiki > TechNet Articles
Jul 30, 2017 - amazon fire stick fire hd customer service number 1-866-316-6909 , amazon fire stick fire ... How do I connect to wifi on my amazon fire stick?
Amazon Fire TV Stick Customer Care Service 1833-220-1222 Support
www.teqguru.com/amazon-fire-tv-stick-not-connecting-help-support-customer-care.h... Amazon Fire TV Stick customer care Service/Amazon Fire Stick not connecting issue support number 1833-220-1222 Amazon Fire Stick technical helpline ...
Amazon Fire Stick 1-800~970-9340 Amazon - MapQuest
https://www.mapquest.com/my-maps/dcae4753-b611-4318-833c-45ff13c2fbd1 Amazon Fire Stick 1-800~970-9340 Amazon Fire Stick Technical Support Phone Number Amazon Fire Stick Tech SupportAmazon Fire Stick 1-800~970-9340 ...
amazon fire stick technical support Google Search
Aug 30, 2017 | Televison & Video
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Hi, I purchased a firetvstick but it does not respond after plugged into my smart tv. help
Check list:
1) Do you have your fire stick powered?
Connected via usb cable to a power adapter
plugged into a power strip that has the power on,
power switch is off....so on.
2) Do you have your TV input set to the correct HDMI input?
Depending on the model you may have 2 to 4 HDMI inputs.
This is the most common error.
Please make sure the input is set to the correct input
of where your fire stick is plugged in to.
3) If you have power and the input in your TV is set.
And you still have nothing.
Then your firestick might be defective.
4) If it is working, read the instructions carefully.
connect your fire stick to your wi fi and register your fire stick.
Then enjoy!!
Aug 30, 2016 | Amazon Fire TV Stick
Does my insignia ns-p501q-10a have a usb port?
Looking at the manual for the NS-P501-10Q from the product site, http://www.insigniaproducts.com/products/televisions/NS-P501Q-10A.html , the TV has a USB port labeled "Service" on the back above the other input ports and on the left side of the input/output area. Unfortunately, I don't think it will provide enough power for an Amazon Fire stick. It's for updating the firmware on the TV with a data file on a small flash drive.
I'd suggest using an appropriate USB wall charger to power the Fire stick.
I hope this helps.
Jan 12, 2016 | Insignia Televison & Video
Don't know how to get my Amazon Fire stick going
Any HDMI will work, you just have to pick the right input on your tv to see it. If you plug in to the hdmi labeled "input 2" then use your tv remote to select input 2. Also dont plug in the power cable to the telrvision, while convenient sometimes the voltage or amperage of the tvs usb does not supply enoigh power. Use the provided ac adaptor as well
Jan 02, 2016 | Insignia Televison & Video
Can i install a amazon fire tv stick the u s b will not plug in
Amazon.com: Customer Reviews: Amazon Fire TV Stick
www.amazon.com/Amazon...Fire-TV-Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com: Customer Discussions: Fire stick and Samsung TV issues
www.amazon.com/forum/fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
How do I register?
If you are getting trouble regarding amazon fire tv stick device then fix problem to read guide at
https://echoalexasupport.com/fire-tv-stick-support/
Dec 25, 2015 | Amazon Fire TV Stick
I already have appletv plugged into HDML outlet on my tv. How do I plug in the fire stick as well?
You'll need to locate a second HDMI jack on the TV, or install a HDMI switch to manually select which device will be seen on the TV. Make sure you buy switch that has at least as many HDMI input jacks as you need now (and later, too!) to save you from having to buy another later. Here's what google returns:
HDMI switch Google Search
Oct 27, 2015 | Amazon Fire TV Stick
Open Questions:
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
