Question about Tablets & eReaders
My tablet was buzzing and screen had colored fuzzy lines??????
Is my Android tablet LCD screen cracked as well as the digital screen?
and you just learned a 45 dollar lesson . they are not made to sit on .
Aug 06, 2015 | Xelio P1001A-BK 10.1" 4 GB Black Tablet...
Trio stealth tablet theres a line down the middle and black and white one side and color on the other
Sorry to hear this Jennifer. First thing that comes to mind is that it is a crack in the under screen glass. You can test this by applying slight preasure on each side and see if you see any rainbow colors or if you lose the PITURE on the screen. Has it show a screen on both sides of the line? These tablets are known to have issues relating to even the slighted shock or sometimes its caused due to surges from the charge unit. If you have this happen and it does get worse it is about 40 dollars to have a new screen installed. Ill follow your post to see if I can help you further.
Good luck
Chadman
Nov 11, 2014 | Tablets & eReaders
How do I turn off my tablet when it is frozen and buzzing?
On most modern computer devices, just pushing the On/Off switch is only a suggestion and the computer can ignore it (or might not get the suggestion). Try holding the On/Off switch down until the computer turns off (that might take 5-10 seconds).
May 13, 2014 | Nextbook Premium 7 Capacitive Touch...
White screen with colorful lines
If this is a touch screen it is broken. It is probably not cost effective to replace the screen.
Apr 13, 2014 | Nextbook Tablets & eReaders
Fussy screen
I'd recommend seeing a Apple Store and let them look. They'll tell you exactly what's wrong, they won't charge you for looking. Fuzzy Screen sounds like a hardware problem.
Jan 17, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My screen is broken
It might be your screen. Please check with your local retailer if you have a warranty on your computer, to be sure that its you're screen try to plug another screen on it and boot up. Good luck!
Feb 20, 2009 | Toshiba Portege M200 Tablet PC
Tablets & eReaders Logo
42 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
