Question about Boating
Rudder does not lock in down position - Boating
Hubsan helicopter main rotor stops when rudder is used
Being coaxial one rotor should slow down when you apply rudder this causes the bird to rotate but if both slow down you may have a pcb problem .Try holding the bird off the ground and opening the throttle then at 50% try the rudder the bird should be felt to rotate. If it doesn't check the gears,motors ,shafts etc.
Feb 25, 2014 | HUBSAN FPV Lynx 4Ch Coaxial Helicopter
I AP 35 Setup
ensure you are setting correct rudder value.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Air hogs jet set plane won't charge
This situation happened to me too after using it like 10 times it doen't
charge anymore does anyone knw what to do and what is the neutral position for the rudder how does it have to do with charging the plane I know what the rudder is and where it is ,ut don't know how to put it into neutral position.Help???
Jan 20, 2012 | Master Heaters Air Hogs Jet Set Assortment...
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My furuno autopilot 511 has a rudder reference unit which worked and then stopped displaying rudder position. I assumed it broke and replaced it. I still get no display. How can I clear the unit. I had a...
the rudder setup needs to be done. follow prompts, very common to be screwed up, read directions carefully and make sure that if it says steer hard starboard, it is hard starboard before you proceed! 847-746-0100
Jun 01, 2010 | Furuno NavPilot 511 GPS Receiver
Auto pilot will not hold course. Wants to go to port as soon as it is turned on
What model autopilot? If it is a Raytheon/Raymarine try switching the motor leads to see if that works.
May 16, 2010 | Boating
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Carolina rudder does not work properly
Slider to which the pegs are attached is probably binding, take entire mechanism out (2 screws), and lubricate with silicone wax. If that doesn't work, replace sliders and pegs.
Apr 06, 2009 | Carolina Manufacturing Perception Carolina...
Twist Rudder feature interferes with use of rudder pedals.
Ya you can disable it just go to menu of home page>Controls>assign A command> and disable
Jan 24, 2009 | Saitek ST290 Joystick
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
