Question about Glacier Bay Home
How do I remove the handle from my Glacier Bay Flapper toilet? I need to remove the water bowl to get to the leaking screws in the bottom of the tank.
    Top Expert:
  • Glacier Bay Master
  • 36,580 Answers
Some have a nut inside the tank
Posted on May 06, 2017
HOW TO SET WATER LEVEL GLACIER BAY TOILET
There should be a adjustment screw at the top of the fill valve, screw it up or down to adjust the tank level.
Sep 13, 2014 | Fluidmaster Glacier Bay Flapperless Toilet...
Glacier bay toilet leaks around the flap
The flapper replacement comes with a rubber ring that slides down over the fill tube to seat. If the old flapper ring does not remove easily, you may have to cut it to remove it. The replacement flapper also comes with ears that mount over hooks at the base of the fill tube on some toilets. You cut the flapper where indicated to remove the ring before installing.the ears on the hooks. If you buy a carded replacement, all of this information will be on the card. If not, someone at the point of purchase may be able to explain. Your well water may make it necessary to replace the flapper often but my experience has been that an inexpensive replacement lasts just as long as more expensive ones
Feb 17, 2013 | Home
Toilet loosing water in tank. Makes little hissing noise.
the little hissing noise is probably the valve slowly filling the tank back up and the water leaking out is probably because the flapper ball needs replaced. You can see it and get to it and replace it very easily, it is the black ball in the bottom of the tank, it has a chain going from it to the flush handle.
First make sure the chain has not flipped over the handle or gotten twisted, I have seen this happen and it does not allow the flapper ball to go all the way down and seat.
If you rub you finger across the top of the flapper ball and black (deteriorated rubber) comes off then replace the flapper ball, remove the clip from the handle, lift the fubber ears of the flapper ball off of the plastic posts at the base of the bowl fill tube, and replace making sure that there is not to much slack in the new chain, just adjust the clip on the new chain where there is just enough so that the new ball seats.
Make sure you turn the water off to the toilet before you replace the flapper ball your valve in the tank will open to fill the tank and it will run until you get a new flapper in place.
You can het a new flapper for a few bucks at Lowes, Ace, even Wal-mart
Mar 13, 2011 | Caroma Home
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Jan 28, 2011 | Home
Glacier bay gal toilet.
Does the tank lid have a seal on it to keep water from coming out?
May 30, 2010 | Home
Water disappears to below the bowl inlet and stop.
adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Nov 17, 2009 | American Standard Cadet 3 Right Height...
Water want stop pouring
remove lid from tank.see that 'flapper valve' in bottom of tank is seating to stop flow into bowl.adjust chain linking flapper to flush handle. replace worn or broken parts
Oct 01, 2009 | Toto Toilet Onepiece Ultramax ...
Basement toilet won't flush. water fills the bowl and tank fills back up...but toilet doesn't flush
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Sep 07, 2009 | Home
Water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Aug 03, 2009 | American Standard 2002.014 - Champion4...
Home Logo
47 people viewed this question
Top Glacier Bay Home Experts
andrewcahoon
john h
Are you a Glacier Bay Home Expert? Answer questions, earn points and help others
