Question about Murray Garden
I had Murray lawn mower old model engine is on for few second then it slowly off , many time like that , could you help me yo figure out what the problem is ,
    Visited the website for 30 consecutive days.
  • Murray Master
  • 1,017 Answers
Check for old gas if not that clean and rebuild carburator
Posted on Jan 17, 2018
  • 376 Answers
SOURCE: murray riding lawn mower
Nix on safety switch. If it was a safety switch, you would not hear a click when you turned the key to start.. There would be no power going to the solenoid. However, if your engine has the fuel shutoff solenoid beneath the carb bowl, it will make a faint click when you just turn the key to the 'on' position. Probably as thabrain says, a bad solenoid.
Posted on May 15, 2009
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 133 Answers
SOURCE: can't find model number
there should be a data plate somewhere on the tractor with model and ser #. Usually it is under the seat. The motor numbers are usually stamped on the engine cover with model type and code.
Posted on Aug 13, 2009
  • 389 Answers
SOURCE: how to install drive belt murray lawn mower
You can go to , enter your model number and download an owners manual which will have the instructions and diagram on how to do it
Posted on Sep 24, 2009
  • 130 Answers
SOURCE: need a drive belt diagram for a murray lawn mower
Please find attached a "amateur" drawing of the belt routing for the 37x89MA primary deck drive belt. Hope this helps.wefixem.jpg
Posted on Mar 04, 2011
I need a deck belt for my Murray riding lawn mower model number is 13an772s058
If you still have the old belt, even if it is broken. Taje it to your local lawn and garden center that sells parts and service on riding mowers. Have them measure the belt length and width. If the belt is missing, have them look up belt for the model number of the mower you have.
Oct 13, 2015 | Murray Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Where do i find parts for my stanley mower?
Stanley Mowers were made by Murray. Most Lawn mower repair / parts stores have replacement parts for these mowers.
Even if you do not have a model number you can probably use this link (left side of page) to find your part.
If it is just an engine part that you need mose of these had Briggs and Stratton engines onthem and the engine model number and type code are on the air shroud just above the spark plug for engines 4 HP or less.
Jun 13, 2010 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I'm tring to put a drive belt on a murray lawn mower.
Here is a link to a website I like to use for diagrams and user manuals for mowers. You'll need the model number, obtainable from your mower:
Hope this helps... Good luck!
Oct 09, 2009 | Oregon Scientific Oregon Fusion Blade For...
I Have a Lawn General Riding Tractor, I think it's made my Murray. The drive belt keeps falling off. It is model #42504x71a. Ser. # 7386702081f00626. The belt is not real old. A service center says that...
Hi, service manual and parts can be found on amazon, here:
manual: Amazon com lawn general riding mower manual
parts: Amazon com lawn general riding mower parts
after reading manual you can be able to detect your problem and see if you need new part or just small fix. I hope this helped you. Have a nice day
Jun 04, 2009 | Garden
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
Jul 04, 2008 | Computers & Internet
Garden Logo
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
