Question about Troy Garden
Tb22ec troy built. New carburetor installed and spark plug. Ran for about 2 min until I adjusted hi/ low knobs and stalled. Started over and still wont start. exhaust is clear. Any thoughts
  • Troy Master
  • 1,824 Answers
Try to control tankairiation tankfilter but In a serious case but not common an thermal failure in the ignitioncoil .
Posted on May 06, 2017
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
connertamago
  • 37 Answers
SOURCE: Troy-Built TB70SS, 1 year old, will not start even after carb cleaning
check to see that the kill button is not stuck in the contacting position, and if it is, try to get it unstuck. WD40 should help. if it's not, then disconnect the kill wires. now try starting it. if it still doesnt start, then the spark generator is bad. if this is the case, you'll need a new trimmer, or have a small engine mechanic replace the generator. i think its called the coil, not sure at the moment it's 4:00 am for me. anyways, whichever is cheaper is best choice.
Posted on Jun 01, 2009
delgriffith
  • 97 Answers
SOURCE: troy built 6.5 stalls after 10 minutes
sounds like a bad coil/magneto.
Posted on Jun 19, 2009
  • 1129 Answers
SOURCE: How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
  • 124 Answers
SOURCE: Ryobi 720r weedeater. Starts, stalls, won't start.
When you rebuilt the carb did you remove and replace the welch plugs. If you did not, then that is probably where your problem is. Debris, varnish and corrosion can build up under the welch plugs and the unit will not pass fuel.
Posted on Sep 14, 2009
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
Two problems-dont know cause or if related or not. #1 engine backfires,stalls spits hesitate like not getting fuel
This is definitely a carburetor issue... when your rider needs more fuel and air to suffice the engine, it's not getting it. How old is the unit? When is the last time it's had the carburetor removed to he serviced...
Start there....
Nov 01, 2015 | Garden
Stumbling and stallin 2003 Harley RK with Big Bore and stock cam.
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below:
Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 18, 2014 | Harley Davidson Motorcycles
Troy bilt pony riding mower
spray some carburetor cleaner in the intake and try to start it if it starts for a few seconds the carburetor is dirty and needs cleaned. put a new needle in it they are cheap and will solve your problem. take the spark plug out and try to start it. if it spins over freely and blows gas out the hole it is the needle in the carburetor. you may want to check the valves, they may be out of adjustment causing hard starting.
Jul 17, 2017 | Garden
Lawn mowers
Maybe it need a spark plug
May 08, 2013 | Garden
Engine is stalling
Hi Chris, and the usual suspects are:
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Sep 04, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
How does one adjust the carb on a TB22EC
I have replaced the entire carburetor, rear case o ring, spark plug, and fuel lines on this same weedeater and can't for the life of me even get a fire.
Apr 26, 2012 | Garden
I accaidenlty put fuel mixed with oil into my small, 26.2 cc, four stroke tiller (Troy-Bilt TB144)...it ran for a while then started smoking real bad...lost power...and now only runs on idle...stalls when...
Drain the fuel, fuel lines and carburetor. Clean the spark plug with a wire brush, replace if unable to clean thoroughly. Remove the muffler to clean deposits out of the spark arrestor. Use proper fuel and you should be good to go.
I hope that you did not run it so long in that condition that you have deposits on the valves, which would require some engine disassembly to fix.
I hope this helps.
Aug 02, 2011 | Poulan Featherlite Gas Blower, with Low...
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
