Help connect back the bedroom tv and my box of kody google don't let enter
johnnydiode
  • 647 Answers
SOURCE: I am about to receive an LG32LF4700 Freesat/HD TV
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Posted on Oct 28, 2009
gopakumarg43
  • 74887 Answers
SOURCE: kodi wont load
Try a hard reset to this set, and check. If it do not help you, its main system control memory IC is faulty; and should be replaced.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 05, 2015
gopakumarg43
  • 74887 Answers
SOURCE: I just got a kodi Ott TV box and it won't turn on what could be the problem??
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 16, 2016
gopakumarg43
  • 74887 Answers
SOURCE: I bought a OTT BOX X96 KODI 16.1 ANDRIOD SMART TV BOX BUT it is JUST FLASHING on And off I CAN'T PULL ANYTHING Up on It PLEASE help
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Nov 29, 2016
tiagofaia60148
  • 11 Answers
SOURCE: How to buy kodi tv box at discount price?
This website compares the best boxes and their prices https://www.bestdroidplayer.co.uk/best-kodi-android-tv-boxes-2017-reviews-comparison-table/
Posted on Jun 06, 2017
I upgraded my kodi m8 tv box to version 16 and now nothing will stream. I keep getting a version error and looking at the log tells me nothing i can understand
Ok I figure you have a 1g 8g memory box.You may have a full memory and then the box will not work. First I recommend loading the Complete kodi setup wizard which is on google play store. With this program you can clear build and start over and when finished you can also back-up the build in the limited memory box. Then you will not have to start from scratch. I suggest using Kodi no limits magic build as I have found it to be most complete build. There are many tutorials on you tube to help do this step by step. They have been doing updates about every 2 weeks since there has been a lot of changes.
Sep 08, 2017 | TV Box Televison & Video
I have ott tv box withe xbmc kodi 14.2 i have tried a number of times to nupgrade to 17.4 even with wookie help i got all my downloads back but now it wont load kodi
If you have a 1g 8G box then there is not enough memory to load anything newer than 16.1. Make sure you clear the build before you add one. I have found that Complete Kodi set up wizard helps a lot.You can find it on google play store.
Sep 06, 2017 | TV Box Televison & Video
I have the h96 pro android box tv its the 7.1 3g 32 its not stable programs say not responding or it freeze or dont download could someone help me
First of all I would load complete kodi wizard from google play store so you can start with erase build. There are a lot of tutorials on kodi on you tube that will help a great deal.Also make sure you have the latest kodi program 17.4 now also on play store. I like to use kodi no limits magic build as I find it the most complete build out there.
Aug 31, 2017 | Televison & Video
I have a mx android tv box it will not download such has kodi it says unsuccesfull it was fine until i set it to reset because of another prob have i deleted a important thing?
The best thing to do is populate the box by hand. Complete kodi setup wizard will help which is available on google play store. Once you have cleared the build them I suggest installing kodi no limits magic build as it is the most complete one I have found. There are several tutorials on you tube that will walk you thru the whole procedure. Also once you have a working build and after cleanine casch and packages then back up the build with complete wizard. So once you have a problem again then remove build and then back up build and you are working again with little effort.
Jul 17, 2017 | TV Box Televison & Video
Which newly arrived Android TV box support MP3 and WMA audio?
Here, I am providing you some newly arrived Android Tv boxes which support MP3 and WMA audio:
a. TP6 Fully Loaded Kodi TV Box Glod 3GB/32GB
b. MXQ-M9X Fully Loaded Kodi TV Box 2GB/16GB
c. H96-Pro+ Fully Loaded Kodi TV Box
d. T95K-Pro Fully Loaded Kodi TV Box, and much more.
To get the whole specification and purchase these latest models at a reasonable price, you can visit Kodi Box.
the-free-tv-box-kodi-media-center-boxes-that-get-rid-of-cable-a2pdiymc3s1x32javj2nu3ju-4-0.jpg
Jul 07, 2017 | Audio Players & Recorders
After the Kodi icon is clicked on and you click on Phoenix, you just get a message that Phoenix is apart of us and sorry and then it just stays like that. How can I get Phoenix to work again?
Phoenix is no longer being maintained by its creator. It was shut down. Phoenix was the first TVAddon to actually be sued by Dish Network. Check this tutorial to get TVAddons working as an altenative to Phoenix: Fire Stick Kodi Not Working Fix it now KFire TV Tutorials
Jun 07, 2017 | Google Computers & Internet
If you are looking to buy an Android TV box at amazing discount and offers, you can visit Kodi TV Box.
Here, you will find the best collection of these branded Android TV boxes and can also see the reviews and specifications of these boxes. To get details about return policies, payment mode, etc you can click on the link mentioned above.
May 17, 2017 | TV Box Televison & Video
My android mx box as frozen wont show nuthing only start up mbox how do i get past it
Unplug from mains ...then reconnect...go into settings and check if the Ethernet or wifi is connected....sometimes restarting the router puts things right...without that you can't proceed....if you have not already done so download kodi version 14 as this seems to be quite stable.once downloaded go into API installer and direct to your internal sd to locate the Kodi apk file.once installed you can then set up your ad dons.a quick simple way is to use a community build from tvaddons.ag.if you are someone who bought from droidsticks you can use the droid stick wizard providing you still have the codes.get back to me if you are still stuck.
Apr 13, 2015 | FocalPrice MX Google Android 4.2 Dual-Core...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
