Question about Technics Audio Players & Recorders
My A/V Receiver Technics SA-AX910 presents a peculiar malfunction. It works fine for months. After this time keeps turning on and off permanently. I've replaced Q901 and works fine for about a year.
2 Suggested Answers
SOURCE: Describe your I have a technics sa ax910 turning
Was a loose connection on a POWER-SUPPLY and a "C I S " BOARD. Had the repair done in about 1 HR as I waited. $137.51 taxes in.
Posted on Feb 01, 2010
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Jan 01, 2011 | Technics SA-AX910 Receiver
1 You may have a failing power supply regulating circuit in you amplifier and the fail safe circuit is trying to protect the rest of the circuit.
2. there may be a voltage overload at the primary side of the power supply circuit which in this case is causing it to shut down.
Jan 06, 2010 | Technics Audio Players & Recorders
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Technics SA-AX540 Receiver
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Mar 02, 2009 | Technics SA-AX540 Receiver
Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Feb 18, 2009 | Technics SA-DX950 Receiver
Technics receiver shuting down
check fuse on the inside of the stereo.
Nov 25, 2008 | Technics SA-DX930 Receiver
Technics SA-DX940
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Aug 04, 2007 | Technics SA-DX940
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
