Question about The Watches
I moved and can't remember how to set my cuckoo clock. I bought it Germany in 2004, it came from the Black Forest.
4 Suggested Answers
kaiserclock
SOURCE: Kaiser clock model kc-2.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Posted on Mar 09, 2011
mikes112
  • 56 Answers
SOURCE: I have a cuckoo clock bought a rew years ago in
The easiest way is to remove the larger link/hook from either end of the chain and then place the clock upside down,and open the back of the clock and then put the chain through the hole on the side that the weight hangs on. Then guide the chain onto the wheel with the large teeth, and then turn the clock on its side so the end of the chain will fall around the wheel and then with a screw driver carefully turn the wheel and then turn the clock right side up as you turn the wheel and the chain will follow around the wheel. Finally pull the chain through the other hole.
Posted on Jan 02, 2012
compac
  • 10 Answers
SOURCE: How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Posted on Jul 13, 2012
Testimonial: "Thanks so much for your help. I now have my cuckoo back in sync. I really appreciate your your help. Thanks so much."
Cuckoo and action doesn't work
Is this a mechanical cuckoo, or an electronic? If mechanical, probably the strike mechanism is jammed. You might barely, HEED: just barely pull on the weight a tiny bit and see if this does anything. If not, time to get it serviced. If it is an electronic cuckoo, check batteries and contacts.
Nov 04, 2017 | The Watches
I need instructions for Acctim FELDBURG Cuckoo Wall Clock
Hi, not much info on this clock specifically. This might help though :)
Instructions Quartz Cuckoo Clocks
Jan 31, 2015 | Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
Jul 13, 2012 | Watches
My cuckoo clock dont tick
I had a cuckcoo clock I got when I was in the Navy, and it came from Germany. I had the same problem. Have you ever heard the expression, "Stop yanking my chain"? Well, this is exactly what I had to do to get mine working... Well, since they wind up via the chain...
Aug 26, 2010 | Watches
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
kaiser clock
Aug 04, 2010 | Watches
I have a cuckoo clock bought a rew years ago in Blackforest Germany when i visited the place. One of the chains has slipped off the wheel and so I am not able to pull it for winding. The chain is simply...
Do it yourself. There is no need for any repairs - you just have to put the chain back on wheel. Take a look on another chain in the clock and put the slipped chain back on wheel exactly in the same way as another chain. Use tweezers to reach the chain.
Rate me, please.
Mar 27, 2009 | Watches
Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
Nov 02, 2008 | Watches
Watches Logo
27 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
vince
Are you a The Watch Expert? Answer questions, earn points and help others
