Question about Magic Chef Washing Machines
E2 signal on my Magic Chef washer - Magic Chef Washing Machines
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
  • 5 Answers
SOURCE: MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Posted on Jul 19, 2009
Karthik316
  • 187 Answers
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Posted on Jul 23, 2009
  • 129 Answers
SOURCE: MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Posted on Feb 02, 2010
What make a magic chef washer leaks only on rinse?
It probably leaked during washer very little by the time it comes to rinse you'll see more water
Jun 07, 2016 | Magic Chef Washing Machines
What is the error code E2 for Magic Chef 2.1 cu. ft. Top Load Portable Washer?
I put this answer in the comments but re-posting here because I didn't know what I was doing : )
The Magic Chef 2.1 cu ft Portable washer manual says that its a door malfunction and the solution is to open and close the door. That did not work for me so if you're having the same issue that I am it may be that your washer is not level. I had placed mine on top of a few folded throw rugs to stifle noise (I live in an apt, on the second floor) and the rugs were uneven. As soon as i adjusted them, the washer began to work again. I hope this helps.
May 26, 2014 | Magic Chef Washing Machines
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
Try these
  5. Test the motor
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Washer wont spin
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
Nov 22, 2007 | Magic Chef CAV2000 Top Load Washer
Washing Machines Logo
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
