Noisy sound very loud all the time, like a disk continously spinning on RT2781BE home stereo system
sanjin
  • 56 Answers
SOURCE: subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Posted on Mar 10, 2008
  • 32 Answers
SOURCE: very noisy spin
sounds like you have a broken stanchion on the rear of the basket,usually a fatal diagnosis because price of repair excess cost of new one.check your manual and look under warranty.if you have a extended warranty on parts(stainless steel basket and tub)you would only have to pay for labor...good luck
Posted on Sep 29, 2008
SOURCE: Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">x.x@eds.com> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Posted on Jan 05, 2009
myjosh007
  • 530 Answers
SOURCE: Monitor working properly but it sounds continously,very noisy
hi im josh in cebu phils.may i help you? Friend try this solutions:
Problem: Your Monitor Doesn't Display—The System Unit Issues a Series of Beeps Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously.)
Problem: Your CRT Monitor Doesn't Display—It Makes a High-Pitched Whine This whine indicates that your CRT-type monitor, for some reason, is operating at the wrong frequency. Turn it off immediately—this problem could seriously damage your monitor! Now check the settings on your video card. Chances are that it's set to a higher resolution than your monitor is capable of displaying. If this isn't the problem, your video card itself could be defective. If your video card is okay, your monitor might be defective.
Problem: Your CRT Monitor Pops and Crackles and Starts to Smell Like the rest of a computer system, monitors can get dusty. When dust builds up inside the monitor, it can generate static charges.
It's also possible that the power supply inside the monitor has become defective. If the monitor demonstrates these symptoms, turn it off immediately and take it to a repair center. The technicians can either clean your monitor or replace the power supply if necessary
You may visit your monitor services center if the problems stills occur after performing the solutions mentioned. hope i helped you friend good luck
Posted on Mar 10, 2009
jibins
  • 67 Answers
SOURCE: Bosch Maxx 5 very loud noisy spin
the spinner to motor coupling is damaged by the wear and tear..please replace it
Posted on Aug 24, 2012
RCA Reciever no sound
You could have speaker wires shorted, putting unit in output shutdown. check them. Turn unit on and listen very closely for about 5-6 seconds for a click (the relay for okay output condition). If not heard, have unit serviced or check for blown output fuse. Of course they don't blow without a reason.
Aug 23, 2016 | RCA Audio Players & Recorders
Are worn carbon brushes noisy or do I have a Bearing in trouble.
you might get a clicking noise from the brushes but it wont be loud ( its metal on metal sound ) but bearings will sound like an aeroplane taking off ( very loud )
May 07, 2015 | Washing Machines
Noisy spin cycle
IT SOUND LIKE YOUR REAR BEARING IT GOING OUT ON THE WASHER
Nov 02, 2012 | Kenmore Washing Machines
I have a 2000 lincoln navigator,the compressor is continously kicking on also its real loud when it does kick on,possibly the rubber gromets to keep the compressor from vibrating dry rotted causing loud...
check the mounts and also have the pressure checked with some ac gauges. if a system is over charged the compressor will cycle on and off constantly and can cause a knocking sound.
Apr 01, 2011 | 2000 Lincoln Navigator
Strange clicking sound from my book home edition 1TB. Disk is not visible in any system Mac or Windows.
Is the clicking sound continous? Did the disk fell down or did something else hit the dis? The symptoms are bad for the data you have in the disk... If the sound isn't constantly, leave the disk on the computer for a long time, it's possible to work again....
Stelios.
Feb 22, 2010 | Western Digital My Book Home Edition 500...
Same thing - loud ticking sound and sound system disabled=plshlp?
the ticking is most likely the injectors, since the high pressure fuel system was introduced the injectors are very noisy. however, if you have had the campaign on the fuel rails done recently, take it to whoever did it and make sure that they installed all the sound deadening. the stereo is most likely the amp if its making a high pitched whine noise all the time.
Aug 16, 2009 | 2007 Lexus LS 430
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
26 people viewed this question
 Grubhead
Grubhead
