Question about LG 62SX4D 62" Television
How to change the lamp.
The lamp died so I ordered the part. How do I replace it?
  • 1 more comment
  • Anonymous Mar 06, 2008
    I changed the buld how do i reset the bulb timer?
  • chrisdompier Aug 07, 2008
    replaced the lamp
    got the service remote
    what now?
  • MelB01 Jan 02, 2009
    Do I need the service remote for when I change the bulb?
Looking at the face of the tv there is a hatch on the right side near bottom of tv 2 screws open look inside u will see a silver box undo the 2 silver like screws then pull on handle thats across the back of the lamp box u now have the lamp . make sure that u have turned the tv of 10 mins before or its to hot to touch .
Posted on Nov 26, 2007
I wasn't able to find their web site. The suspected website is for sale and I found that the inventor has died. It may be that it is no longer being made under that name.
This is a link for ordering replacement bulbs.
Tensor Corporation BULB ORDER FORM Free Online Doc
Oct 15, 2014 | Televison & Video
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Jan 27, 2011 | 1999 Volvo C70
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
How do you change the bulb?
Hello :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
micro fiber duster
avoid touching the bare projector lamp
Here are the steps that explained in the manual :
Lamp Replacement Procedure:
1. Switch off the power to the projector by pressing the Power/Standby button.
2. Allow the projector to cool down for at least 30 minutes.
3. Disconnect the power cord.
4. Use a screwdriver to remove the screws from the cover.
5. Push up and remove the cover.
6. Remove the 2 screws from the lamp module.
7. Pull out the lamp module.
Apr 13, 2010 | Optoma EP747 Multimedia Projector
Sony 51'' projection Tv after one hour color chngs to Green
I've come into this problem before, it sounds like the lamp is dieing .. It could also be that a wire connected to the lamp is attached to the wrong post or isn't connected at all.
Depends on how long you've had that lamp installed and use time. If you've been using it for quite some time, 2.5/4 years and never replaced the lamp then it's most likely the lamp that needs to be changed, otherwise if you've had the lamp changed recently, i'd be leaning towards, a wire in the wrong place or not attached at all. Best of luck :)
Oct 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Samsung 50" DLP Lamp died, new lamp will not light`
Bad news.  Mine did the same thing.  Mine is the 61", but the internals are basically the same.  I replaced the lamp and the problem was fixed.  Then after a couple days, it died again.  I replaced the ballast, to no avail.  Took it to the certified repair center and they said I needed a new DLP Light Engine.  They wanted $1250 to fix it, but I was able to order one online from for $700 and fixed it myself.  No problems since.
Your certified repair center will charge a minimal fee to diagnose and then you can fix it yourself if you choose.
The easist fixes for the lamp problems are A) replacing the bulb and B) replacing the ballast.  Anything else, you'll want a certified tech to diagnose the problem.
Jan 17, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony cineza vpl hs51 projector won't project
Something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
The lamp may not have been changed - just the timer reset - How many hours has the lamp really done - 1000, 3000, 5000?
If you know that the hours are genuine, then was the quartz bulb contaminated with a touch of oil from skin contact?
This will substantially shorten lamp life, due to the quartz going milky and opaque.
The easiest way to check, is to pull the lamp and have a look at the bulb.
If need be replace the lamp and reset the lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS51
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
Dec 07, 2008 | Sony Projector Lamp for VPL-HS51
Samsung HLN5065W
order the lamp by calling 1-800-726-7864 (1-800-SAMSUNG) The lamp is on the back left of the TV ..... not too hard to replace
Nov 05, 2008 | Samsung HLN5065W 50" Rear Projection...
LG 62SX4D 62" Television Logo
602 people viewed this question
Computer Repairing
Computer Repairing
