Question about Watches
I need to set chronological on athletic works dual time watch 4 button function ah1069 107 watch
SOURCE: columbia watch - set time
Hope this helps!
I found it finally!!!
Good luck, I hope this helps you!!!
Columbia by Fossil Customer Service Contact
Contact this seller Phone: 800-449-3056
Posted on Jan 11, 2008
SOURCE: aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
SOURCE: Setting Time on Aqualite 4 button 30M watch
hold lower left button for 3seconds, use upper right to select hour, minute. lower right to change. lower left to complete change.
Posted on Jul 21, 2010
SOURCE: how do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Posted on Jan 15, 2011
Can we have the instructions for this watch? Can’t see me to find online we and we can’t not do any d ungrateful with the new battery installed.
https://oureverydaylife.com/how-to-set-my-athletic-works-watch-12234179.html
No instructions are online for AW91-729 Walmart Athletic Works watch.
Article online that may help:
How to Set My Athletic Works Watch
by John Smith ; Updated September 28, 2017
Related Articles
How to Set Your Watch
How to Set Timex Watches
Freestyle Predator Watch Instructions
Swiss Military Watch Instructions
Wal-Mart sells affordable watches by the company Athletic Works. It's sometimes common to throw away the directions, only to discover later you can't figure out how to set the watch. The problem is that Athletic House doesn't have a website or any manual online, so you may have difficulty getting help unless you find someone who also has the watch.
There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
Press the start button to change minutes.
Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Press the reset button to switch to the date, starting with the month, and press start to change it.
Press reset one last time to switch from month to the day, and again press the start button to switch days.
Press the mode button to finish the changes.
Tips
Depending on which type of Athletic House watch you have, the buttons might be in different places. But the steps remain the same, regardless of button placement. If you have more questions about your watch, bring it to Wal-Mart and ask to see a manual.
About the Author
John Smith began writing back in 2003. Smith is a technology writer currently living in Lansing, Mich. His articles have appeared in online publications including PC World and IGN, where he specializes in mobile apps for both Android and iOS. How to Set My Athletic Works Watch
Jan 29, 2018 | The Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Athletic wrist watch stuck in 24 hour mode
    Maddening, isn't it? Fortunately the solution is here:
    http://www.ehow.com/how_5593310_set-athletic-works-watch.html
    1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
    2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
    3 Press the start button to change minutes.
    4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
    5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
    Apr 30, 2009 | Watches
    Need manual/User Guide for an ''Athletic Works'' watch, model V403
    Dave,
    If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
    Apr 26, 2009 | Watches
    With time displayed:
    Press lower right, then upper left.
    Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
    I have a athletics works AW60451W wrist watch that has gone to military time How do I get it back to civilian time
    Go to the set hour function and cycle through the hours until you see the AM/PM display at the bottom of the watch face.
    Mar 08, 2009 | Oakley GMT OAK0531 Wrist Watch
    CAN'T SET TIME
    I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
    My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
    Feb 28, 2009 | Oakley GMT OAK0531 Wrist Watch
    Timesetting on Athletic Works wristwatch
    I have a AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
    Feb 17, 2009 | Oakley GMT OAK0531 Wrist Watch
    I have an Athletic Works watch and can not turn off the alarm.
    the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
     A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
    Jan 24, 2009 | Casio Sea-Pathfinder SPF40-T Wrist Watch
    Athletic works watch
    I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
    http://www.ehow.com/how_4587869_set-aquatech-watch.html
    Give it a try.
    Clem S
    Sep 23, 2008 | Watches
    Watches Logo
    26 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
