Question about Tablets & eReaders
Tablet rings without being connected - Tablets & eReaders
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
I have a 10inch Tablet that my son put a password on but has forgotten the password. Is there anyway to reboot the tablet without knowing the password?
It's hard to tell you exactly how to do this without knowing which tablet you have. I'm guessing that it is an Android tablet and some of them (if you linked them with a Google account) will let you unlock them remotely through Google. This will have to be done by entering in the wrong password several times and then it will prompt you to try your Google account.
If that doesn't work you will most likely have to perform a hard reset on the tablet. Understand that doing so will wipe any personal files and reset it to the same state it was when you pulled it out of the box for the first time. I would recommend connecting your tablet to your computer and downloading any pictures or music you have on it first.
To reset the to reset the tablet some tablets have a small pin hole located on them that you can insert a paperclip into to reset the tablet. Some tablets will let you enter a development mode by holding down the volume-up key and the power key for several seconds. This will let you reset the device to factory settings.
Feb 17, 2015 | Tablets & eReaders
How does the iconia one 7 tablet hold the wifi password without you having to type it in every time you turn it on?
When entering the password there is a tick box that allows you to save the settings and connect whenever this wifi available, check the settings from the password page!
Dec 27, 2014 | Acer Iconia One 7 B1-730HD-11S6 7-Inch HD...
How do you get the rca RCT6378W2 tablet connected with a Bluetooth keyboard
If your tablet is Bluetooth-enabled, follow the set up instructions that came with the keyboard. Basically, you turn Bluetooth on on both the keyboard and the tablet. Start the process of pairing and connecting from the tablet. If you are asked to enter a password/passkey and it is not specified in the keyboard's manual enter '0000' or '1234' (without the quotes). Note that the password is required only for pairing, therefore it will happen only the first time. If your tablet is not Bluetooth-enabled, you cannot connect the keyboard to it.
Dec 21, 2014 | Tablets & eReaders
I DONT HAVE INTERNET ON MY HTC JETSTREAM TABLET BECAUSE IT WILL NOT HOLD THE CONNECTION WITH THE HOME WIFI. CAN YOU HELP, PLEASE?undefined
How long has your tablet been turned on without rebooting it? Tablets are just like computers, they need to be rebooted every so often or they "forget" how to do certain things, and wi-fi is one of them, in my experience. Turn off your tablet, let it sit for a minute, then turn it back on again. This should help. If not, check under Settings to make sure someone hasn't accidentally turned off the Wi-Fi button or put the tablet in Airplane mode - both of these things will effectively keep your tablet from connecting. I would try rebooting first.
Oct 19, 2014 | HTC Jetstream 10.1" Tablet Android 3.1...
How to reset SVP TCP-1020 tablet
In most cases, the battery comes loose from the main connection. Those tablets do come apart, the back just presses on.
Jul 30, 2014 | SVP 10-inch Tablet
Dropped tablet, screen is rainbow
How can I get my Polaroid S8 to connect to a WEP encryption wifi router without changing the router security?
Dec 30, 2013 | Polaroid 7-in. Internet Tablet - Other
How to sync email on wifi connection?
It just got the network, of course you need to get in your mail account then check it. It could not sync any email without a mail account. Or ask Samsung for directly help.
Android 4.0 Tablet PC
Jan 12, 2012 | Samsung Galaxy Tab 101 Tablet...
Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Sep 03, 2009 | Gateway m1300-3004372 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
