Question about Garden
Mower deck belt keeps coming off how do I adjust it on a pony 42 inch
SOURCE: Need diagram of deck linkage on Craftsman 42 inch
Go to sears parts direct and punch in your model #
Posted on Mar 27, 2009
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 376 Answers
SOURCE: LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Posted on Jul 04, 2009
SOURCE: 42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Posted on May 01, 2012
Why does my Troy Bilt Pony Mower deck keep running after it is disengaged
-The belt is too tight. It should be free when the engine is running.
-Adjust it. It'll take care the problem. (I'll say it'll need about 3/4" to 1 1/2 clearance)
Good luck
mai
Sep 01, 2014 | Troy-Bilt Garden
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Need drive belt diagram and instructions for replacing the drive belt on a craftsdman dlt 3000 lawn tractor.
Your mower will have a model number like this one:
917.275820 The pictures in the manual below are for the 18.5 - 20 Hp 42 inch deck riding mowers.
It brings up this manual: (3.71 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0411347.pdf
See page 23 under service and adjustments for deck belt routing picture.
Thanks for choosing FixYa,
Kelly
Jul 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Deck belt keeps coming off
check the pulleys and mandrels if any are loose or binding repair or replace as necessary check the alignment of the deck and drive pulley if the support bolts are loose or out of alignment tighten or adjust as necessary
Apr 25, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    Craftman 42 inch mower slings deck belt everytime
    MOST OF WHAT YOU SAID IS CORRECT.NORMALY WHEN YOUR BELT STARTS DOING THAT YOU SHOULD REPLACE BOTH YOUR DECK SPINDLES AS THERE IS NO ZERK FITTING TO ADD GREASE.THIS HAPPENED TO ME A FEW YEARS BACK.HOPE THIS HELPED
    Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Ineed the diagram for a 42 inch deck troy bilt
    We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
    Apr 26, 2009 | Garden
    Garden Logo
    26 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
