Question about Garden
My yardman riding mower wont stop when let off gas. What is wrong?
rockitman187
  • 2559 Answers
SOURCE: Yardman riding mower cutting uneven
You need to park on a level area and lower the deck to it's lowest setting and adjust the deck with the large butterfly nuts on each side,just under the foot pan,just loosen and let the adjusters fall into place,Tighten back up and it should be set.
Posted on May 15, 2009
SOURCE: mtd yardman riding lawn mower will barely move or
rock it back and forth, and pull the shifter to neutraLwith out mtor running.
Posted on May 29, 2009
SOURCE: replace drive belt yardman rideing lawn mower
Changing a Drive Belt Model # D02423
Posted on Aug 16, 2009
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
My yardman is out of alignment
If this is a zero turn as pictured then there is nothing wrong with you wheels unless they are not moving at all. They will correct as they hit ground and spin freely on uneven ground when not in contact. If it is stuck in one position then you may have a bad bearing and need a new wheel post.
Aug 23, 2014 | Yardman Yard Man Select Series 42"...
Yardman model 131784GWhere exactly is the safety switch??
there will be several. one is under the seat that works when you are sitting down one is on the gear lever so that unless you have the brake on it wont work and one will be on the cutter lever. they are relatively small around 2" long about 3/4 " high and maybe 3/8 " wide. with a lever or button on one side and 2 wires
Jun 03, 2013 | Garden
Blades will not turn on lawn mower
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
Jan 11, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Yardman 26cs starts briefly then stops.
check the vent on the gas cap
May 23, 2012 | Garden
Yardman mower wont run in lower speeds how to adjust
the pulley in the center the one that the belt from the engine and the other to the rear axle needs to slide the pulley changes where the belt rides in turn changes the speed most times the pulley can be removed and cleaned and reused
May 21, 2012 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
