Question about Electrolux Cooktops
Finish on electrolux cooktop is comiming off after minimal use. Is that normal.
  • 595 Answers
No it is not normal, I do however assume that you removed all protective covers before use. You will need to contact the supplier of unit or elecrolux for replacement / repair under warrenty.
Posted on May 06, 2017
My Electrolux stove top piezo ignition won't stop clicking how do I make it stop
Hello Jan, thank you for your inquiry!
From what you have described your Electrolux cooktop will not stop clicking. This could be an issue with your burner or gas connection. I would suggest having a professional technician out to look over the cooktop as well as disconnecting your gas connection. I hope this information is helpful to you. -Matt
Mar 08, 2016 | Electrolux 36 in. Designer Series...
Electrolux electric cooktop heating element is changing temps + others are coming on by themselves?
I appreciate your post, friend!
Based off what you have described your Electrolux cooktop is changing temperature and is coming on at random times. This could be an issue with your control panel or a wiring harness. I would recommend seeking assistance from a professional technician for a proper diagnosis and repair. This will help you avoid unnecessary part purchases. -Matt
Mar 29, 2015 | Electrolux Cooktops
Electrolux Cooktop Hybrid error E07- sometimes, cooking gets interrupted with E07 code and shuts off the panel. On next turn on, usually works okay. Could you describe me the error code? Thanks!
I see that you are having an issue with your Electrolux cooktop displaying a "E07" and shutting off. An "E07" code stands for an issue with your key sensor timer and this could be a potential problem with your right, left, or center board. This may not be a simple DIY job and I would highly recommend having a professional technician come out to diagnosis your cooktop. The technician will have the appropriate tools needed for properly diagnosing your cooktop. This step will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 19, 2015 | Electrolux Cooktops
Electrolux hybrid cooktop showing flashing 8
Based off what you are describing your Electrolux cooktop is flashing error code "8". Normally, an "8" error code stands for key sensor for cook place 3. This means you could have a problem with your center board or left board. I would recommend performing a reset on your cooktop which can be done by flipping off the household circuit breaker for ten minutes. If the issue remains I would consult with a professional technician for diagnosis and repair on the cooktop. I hope this helps to some degree. -Matt
Oct 20, 2014 | Cooktops
Electrolux e21
Thank you for your post, friend!
I understand that your Electrolux cooktop is flashing an "E21" error code. Based off the information I was able to look up it sounds like a possible issue within the left board. I would suggest seeking assistance from a technician for proper repair because some of these intricate parts do require precision and patience. Therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. -Matt
Sep 28, 2014 | Electrolux 30" Induction Cooktop
Hairline crack 10 inches long on electrolux cooktop with 1 inch long "bubble" I did not drop anything on the cooktop
mainly caused when customer uses aluminium on the glass top.
only solution: new glass.
Oct 21, 2013 | Electrolux Cooktops
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
Please tell me how to unlock and Electrolux induction cooktop.
If it's in child safety mode, switch on the appliance and touch and - at the same time.
Jan 22, 2011 | Electrolux 36" Electric Hybrid Induction...
Cooktops Logo
67 people viewed this question
Top Electrolux Cooktops Experts
Paul Carew
rugby prop
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
