Question about Boating
Can I use high pressure gear oil in my outboard motor leg 80 / 90 with out damageing it?
None of this answered my question ! can I use high pressure gear oil in my in/out board mercury motor leg???
Posted on May 07, 2017
leetamara
  • 702 Answers
SOURCE: 1989 Ford Mustang GT Drop in Oil Pressure gage
I hate be the bearer of bad news but it sounds like you bottom end bearings are getting worn out. You have excessive bearing clearances causing your drop in oil pressure.
Posted on Jul 13, 2008
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
  • 86 Answers
SOURCE: sealing the gear casing on an old Chrysler 20 outboard motor.
You can get aftermarket seals and such as long as they match the old ones. You can also use Lubriplate 105 in the gearcase instead of the High Performance gear oil. The 105 is alot heavier and will not hurt it. It will actually get you more life out of a tired gearcase. The main thing that you want to remember is that you have to put the engine in fwd gear and then disconnect the shift linkage. That is so that when you are reinstalling the gearcase you can turn the prop by hand to line up the splines in the powerhead. after you disconnect the shift linkage you should be able to just slide it right out. Make sure that you replace the seal under the waterpump base also.
Posted on Aug 10, 2009
  • 91 Answers
SOURCE: suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Posted on Jun 20, 2010
  • 1168 Answers
SOURCE: I have an Evinrude outboard
Hello Pvsteward.
I would not recommend an electric pump to boost your pressure. A definite fire hazard as well.
A boats biggest enemy!
If you have a built in fuel tank it will have an anti-siphon valve installed.
The valves are there to prevent fuel spillage in case of a hose rupture.
These valves can trip at full throttle on big outboards due to the large amount of fuel consumption.
You may need to get a valve capable of a higher flow.
This happened to me when I went from a 135 to a 175HP.
A new valve did the fix.
Have you checked the screen in the fuel pump? In behind the inlet many OMC pumps had a screen to filter out debris. It may be worth a look.
If you would like further advise on this, please ask me in a comment.
Thank you for using FixYa.
KL
Posted on Mar 16, 2011
I have a 2003 yamaha 40 hp four stroke outboard, this year started up seemed to run great after about 25 minutes i shut it down an hour later checked oil crankcase full of water
water in the engine crank case oil --major seal or corrosion problem in the motor
water in the leg gear box --
pump seal on the drive shaft
Jun 01, 2017 | Yamaha Boating
How do you change the gear lube in a Evinrude Triumph 70 hp outboard motor?
Hi .
There should be two flat screws on the lower leg, remove the bottom one and then the top.have the motor fully down position to drain, when filling with new oil it has to be done from bottom to purge the air out, Gear box is full when foil comes out top screw, install top screw and then bottom, you'll lose a bit of oil when bottom is removed install . if not sure have a look on YouTube, it should help you out.
Good luck.
May 28, 2016 | Boating
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
Johnson 235HP Outboard - oil leaking from bottom leg - dark black so picking it is the two stroke oil
most 2 stroke motors will not burn all the oil in the mix and that unburned oil coats the exhaust leg and leaks out the thru hub exhaust and parting line of the lower to the housing. so keep some windex handy and clean it up.
Oct 09, 2012 | Clymer EvinrudeJohnson Outboard Shop...
What type of oil for a 90 horsepower 1998 engine for a boat?
The outboard leg/transom leg oil is most important, where the gears drive the propeller it will need a heavy oil like hypoid gear oil No. 90. If it is a four cycle motor which doesn't need to have oil mixed with the gas, the base of the motor will have an oil plug and dipstick, and most likely take a high performance oil which acts as a coolant as well as a lube oil, so keep it right on but not over the full mark to avoid deadly engine heat.
If it is a Two-cycle motor you will need a 2cycle oil to mix with the gas according to that engine's particular mix strength on the instructions. Some are automatic oilers - 2cycle injection so you just keep the 2cycle oil tank full. You need to find a sticker on the motor or brochure to get the right oil weight and weather it can take the new multi-weight synthetic oils or not. Also oil the cables and steering pivots and all joints after you take it out of salt water and do your routine flush-out for the leg coolant water system with a hose - the coolant pump in the leg is not rust proof at all, even for fresh water boating.
Jun 21, 2011 | Garden
How do i replace a force 120 impellar pump?
Most impellers are in the leg and require the lower oart of the leg to be removed by disconnecting the gear linkage and undoing the bolts that hold the lower half of the leg on, they are just above the water intake.Don't forget the bolt near the prop. Wiggle the leg and slide it down to remove, then place the leg on the bench. The drive shaft protrudes through the impeller housing, remove the bolts that hold the housing on and slide it off. When fitting the new impeller be sure to fold the fins in the correct direction. When re installing the leg be careful to align the cooling pipes correctly.
Cheers, Timo.
Apr 16, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Sealing the gear casing on an old Chrysler 20 outboard motor.
May 17, 2009 | Boating
2008 Yahama 90 2 stroke outboard lower unit fluid leak
Ok by fluid I assume it is gear oil leaking yes?
There is every chance there is the smallest seal leak there that may only be present once the gear case gets a little pressure in it, either through use, or through expansion as the leg heats sitting in the sun even. Have you got a new washer installed under this screw to properly seal it? Usually a nylon type washer is best.
Also, how do you know the lower unit is not leaking or have water intrusion? Have you drained the gearbox oil recently? If so what color was the oil, milky looking at oil or good semi-transparent oil color?
Mar 16, 2009 | Boating
Need oil change in water
If its a 2 stroke, there is no oil to change, if its a 4 stroke, you can pump the oil out with a small diameter tube pump.Depending on the motor, you can get it through the dipstick or the fill opening. If you need to change the gear oil, there is no way to change it while in the water. Stop by a marine supply store and get some oil absorbsion pads (diapers) in case you happen to spill any oil into the water
Mar 11, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
