Question about Exercise & Fitness
Some of the display numbers are not lit properly showing a 6 for an 8 and maybe a 1 for 4, 3 for 9.... I have taken the display apart and see no problems with the connector or ribbon wire.
2 Suggested Answers
jonsnell4
  • 26713 Answers
SOURCE: Samsung range with digital display not working properly. Clock shows half of the numbers.
Replace the display board. There will be a segment driver that has failed.
Posted on May 06, 2017
May 06, 2017 | Samsung Ovens
Have a Harris Vent Free Propane Gas Log, 65% gas left, the pilot will not stay lit.....any help?
check the pilot generator for proper current. check from PP terminal to TH/PP terminal while pilot is still lit. you should be getting well over 250dc millivolts. if not, replace the pilot generator
Dec 14, 2014 | Heating & Cooling
How do I set up the GNC ProTrack GF-0008 Digital Pedometer Plus Body Fat Monitor:
I just won one from GNC and not sur if it is working properly, because screening is flashing in some type of error mode. removing battery was only way to reset.
1. First normal screen is the time display. (only shows 3 numbers.)
2. Press "set" then up/down for correct time.
3. after setting time, press up/down for 12h/24h format
4. Press "mode" & NO 1 flashes, showing Wt 50 Kilo & Man
5. Press "Start" and place one thumb on each end of unit to auto-read body fat.
6. Set weight in Kilos (not sure how to convert unit to lbs, before setting, so maybe use online converter.
7. Set ht, age, man/woman, stride, using up/down arrows.
Follow process for users 2-5,
Mar 07, 2013 | Generic GNC ProTrack GF-0008 Digital...
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
Nov 10, 2012 | Frigidaire Affinity ATF8000FS
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
I have a Meridian Phone (Norstar System). How do I set the number of rings?
Feature 985 write down number displayed
Feature **266344 then 266344
displays Terminals and sets
press top left lit button displays show set
enter extension number
press top left lit button again
press bottom left lit button one time or until you see capabilities
press bottom left lit button until you see fwd to
press change
enter number you wrote down in the first step
press rls
Jan 11, 2011 | NorStar M7310 Corded Phone
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
The dishwasher is running but there is no hot water
maybe the hot water has run out, check, if not then the pipe out and replace it
Jun 01, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
SyncMaster 930B takes 20 minutes at least to become visable
IT SHOWS THAT THE PROBLEM IS IN THE POWER SUPPLY SECTION OF THE LCD. CHANGE THE CAPACITORS PLACED IN THE POWER SUPPLY SECTION. IT WILL WORK.
DONT FORGET TO VOTE.
Oct 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Problems with camera display on kodak APS (something or other......)
I am having exactly the same problem (I have a T550). On the last film I shot, the only way to advance the film was to pull the battery out and re-insert it every time. When I printed that film, all the frames are blank! Kodak's FAQ about "clearing the logic" suggests a solution for that problem. 1. Turn camera off 2. Pull battery out 3. Turn camera on 4. Click the shutter approximately 6 times 5. Turn camer off 6. Repeat step 4 7. Reinstall battery I just tried that but the problem persists. I am now going to leave the battery out for several hours; maybe this will help. Otherwise, well it is time to bite the bullet and buy a digital !
Jun 21, 2007 | Kodak Advantix T550 Auto Focus APS Point...
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
