Howtosafely remove smallflexible piece metal ball chain frm tub bottom stuck ingap between plastic rounpiece
Master_Tech
  • 770 Answers
SOURCE: I had an "f2" error code on Fisher Paykel DD603
i will but need your email address
Posted on May 20, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool top-load washer
from the top and if you dont have the spanner wrench to remove the tub you are headed for a much bigger problem.Note:the spanner wrench ranges from $29.95 and up if you can find one less grab it and re- post this problem and i'll take you through the repair .
Please rate This !!!! Thank you!
Posted on Jul 27, 2008
SOURCE: Ball Bearing Replacement
when spinning , it is noisy. How to overcome it.
Posted on Nov 25, 2008
  • 244 Answers
SOURCE: door opens and gets stuck on casing of motor
do yu mean the trolley opens too far. Check travel limit mechanism (Take cover off). Wires attached. My need new board.
Posted on Jan 17, 2009
  • 24 Answers
SOURCE: spinach stuck in food pusher
PLZ CONTACT 022-23051554 \ 20395757
Posted on Feb 03, 2009
Noise inside the drum
Is there any play in the basket? The gap between the basket and the plastic tub should stay the same. If you are able to put pressure on the upper part of the metal basket and it moves within the tub, the rear support of the basket is damaged or tub bearing is bad. Both are terminal problems. Sorry.
Apr 12, 2014 | Kenmore HE2 Plus Front Load Washer
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
I have a Kokler tub which has a toe tap drain that is clogged. I turned the metal portion of the actual toe tap counter clockwise and removed the top portion and the rubber piece directly under it. Now I...
Someone overtightened the plastic part during installation. There is a threaded portion at the bottom of the plastic cylinder that screws into the actual drain. I have never had to resort to pliers for removal but that approach may be your only hope for removal.
May 11, 2017 | Delta Home
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
I need to remove the aggitator to remove the inner basket? maybe?
YOU SHOULD HAVE A SPANNER WRENCH TO REMOVE IT BUT IF YOU HAVE A SMALL MONKEY WRENCH AND ENOUGH MUSCLE YOU CAN REMOVE IT
Aug 11, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Jul 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
May 30, 2008 | Washing Machines
Het3 elite
remove the bottom panel below tha door. youll see the drain pump in the center,fronr of washer. there is a black hose going from the pump to the bottom of the tub. remove that hose. at the end of the hose there is a plastic ball that is supposed to seal the end of the hose. more than likely there is lint build up on the ball or around where the ball seal. clean the ball and the hose and reinstall. you should be fine after that
Nov 27, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
