Question about Garden
Vacuum lines on 01 yamaha grizzly quad
Murkuni carbuerator
  • 3 Answers
SOURCE: Won't Start, sounds like it is not getting enough
You need to check your compression if its low the quad will not start and dont use a cheap compression tester.
Posted on Mar 02, 2010
  • 130 Answers
SOURCE: My 2005 125 Yamaha Grizzly
IIRC, there is a brake switch which needs to be engaged when shifting into reverse.
Posted on Aug 21, 2010
  • 9 Answers
SOURCE: Yamaha Grizzly 350. After riding for twenty or so
These quads have a thermostat-controlled radiator fan, which won't turn on until the engine is hot. Perfectly normal. Also, if the fan comes on, make sure you use the kill switch to turn the quad off, rather than just turning the key. This allows the engine to cool properly and will save your engine gaskets and other parts. It could take quite a while to cool down...my 2009 Grizzly sure does.
Posted on Aug 23, 2010
kirkx
  • 2019 Answers
SOURCE: i have a 1985 yamaha
What do you mean by "emissions can"?
There are not a lot of emissions stuff on an 85 motorcycle.
If you mean the charcoal canister, you can just plug it at the engine side, but you need to open it on the gas tank side or else the tank will develop a vacuum and won't run.
Posted on Sep 19, 2010
SOURCE: my quad bike is not starting
2 stroke or 4 stroke? check the battery or the carb, check the gas, the oil, new spark plugs?
Posted on Jun 29, 2012
A sucking noise by the carbuerators on a 2000 100hp yamaha outboard
Are any vacuum lines missing or broken cracked etc? Are all unused vacuum ports capped?
Jun 24, 2016 | Seloc Yamaha Mercury Mariner Outboards...
Yamaha grizzly problems
remove and clean carb... and clean it very well making sure nothing is corrodid
Aug 28, 2014 | ATVs
How do I open the seat on yamaha grizzly 350 Quad?
what year? pull cable under seat on some? (under plastic ) has looped cable , just pull it. along edge of seat on others small lever pull up towards seat.
Jul 13, 2014 | ATVs
How do i check the engine oil level in a yamaha 600 grizzly quad
It has a glass window on side of motor. & two marks for low & high.
Dec 19, 2013 | Yamaha Motorcycles
Reverse light stays on quad yamaha 600
reverse switch is jammed, just unscrew and replace
Sep 13, 2012 | Yamaha Grizzly 600 4x4 98 Airbox Air Box
Grizzly 350 wont fire
First check the fuses.check the start ,run switch,there should b some kind of protection for this..possibley a in line fuse??
Aug 07, 2012 | Yamaha Grizzly 350 4x4 07 Airbox Air Box
My 2005 125 Yamaha Grizzly Quad stalls when I put it into reverse?
Aug 17, 2010 | Yamaha YZF-R125 Motorcycles
Jun 16, 2010 | 1985 Yamaha XZ 550 S
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
