Question about Vizio Televison & Video
60" vizio turns off by itself
I have a 60" Vizio that's about 4 years old. It turns off on its own every few minutes. I did replace the power supply and main board. This fixed the problem for a couple months. Now it is doing it again. Any suggestions?
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
  • 1253 Answers
SOURCE: I will start from the beginning. Back in Sept. my vizio tv would just randomly turn off here and there, but would always turn back on. Mid october the tv randomly turned off and never turned back on.
Claim lightning damage, put old boards back in it, sell new boards on ebay while a shop fixes the set for free (minus deductible paid for by selling ebay boards). Tada, repaired!
Or just sell the panel on ebay and buy another tv. Don't break the panel shipping it. 25366436-l0u5xrrbjmm23votbgnhzwek-1-0.jpg
Posted on Jan 12, 2015
gopakumarg43
  • 75581 Answers
SOURCE: I have a Vizio E422VA that will get to the Vizio logo screen, hold for about 1 minute then power off with the power light blinking for about 2 minutes. I have replaced the main board, power supply boa
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Jan 22, 2015
Testimonial: "The blink code does not apply for this model. It seems more of a firmware issue. Someone suggested the 30 seconds reset multiple time which seem to do something because now the tv powers on and goes to the Vizio logo screen and just sits there. After about 2 minutes, it power cycles. I currently have an Ethernet cable and a blu ray connected to it to see if it detects any incoming signals. So far nothing."
Vizio intermittent backlight
You have to check the power supply of the tv. Normally led TVs power suppy is integrated with the led driver. If the led driver is faulty then this type of problems can occur.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 21, 2016 | Vizio E601I-A3 60-inch Class Razor LED...
How do I fix power issue with Vizio TV
Is this the same main board as yours as shown in this thread?
http://www.badcaps.net/forum/showthr...light=SV422XVT
There are two fuses and 3-pin voltage regulator ICs that need to be checked and report the result as shown in this thread:
http://www.badcaps.net/forum/showthr...999#post300999
__________________
Never stop learning
Basic LCD TV and Monitor troubleshooting guides.
http://www.badcaps.net/forum/showthr...956#post305956
Voltage Regulator (LDO) testing:
Inverter testing using old CFL:
http://www.badcaps.net/forum/showthr...er+testing+cfl
Tear down pictures : Hit the ">" Show Albums and stories" on the left side
http://s807.photobucket.com/user/budm/library/
TV Factory reset codes listing:
http://www.badcaps.net/forum/showthread.php?t=24809
Mar 11, 2016 | Vizio 47" E472VLE Full HD LCD TV, Black...
Vizio lego flashing
http://www.shopjimmy.com/vizio-0500-0612-0030-power-supply-unit.htm See the picture The bottom right 1/4 of the picture has some black cylinder shaped parts that fail.
Jan 13, 2016 | Vizio Televison & Video
Have a Vizio WP50-HDTV20A. It goes off after about 3 min. Ideas?
There is a firmware update that is only available through Vizio that usually fixes this type of problem. You can contact them at this number and see if your television is one that needs the update. If so they can supply you with the update free of charge. Vizio Support: Toll-Free: 877.698.4946 (877 MY VIZIO)
877.878.4946
Dec 17, 2014 | Vizio Televison & Video
I have a 2007 Vizio that after about 4 years began having a startup problem where the screen flashes on and off until it warms up, about 10 minutes on a cold day. For the split second that it is on,
Vizio is a good television. But over the years, the Capacitors will dry up. Flat Panel tv's that come from china use cheap capacitors, even in Vizios. There are monitoring IC's, and if the reference voltage (what the capacitor is supplying to the IC), the set will not turn on, or will be intermittent. Replace the Capacitors on the power supply board and see if set comes on. The Reference IC is a good way of telling if a capacitor is bad. The IC monitors reference voltage in the supply area.
Feb 02, 2014 | Televison & Video
Vizio vw26l
replacing the power supply board should solve the issue you can get the replacement power supply board from www.tvrepairworld.com
Jun 01, 2012 | Vizio VW26L 26 in. LCD TV
I have a Vizio VO47LF. Sometimes it turns off by
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | Vizio VO47L 47 in. LCD TV
Kept clicking off while watching and now won't
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go bad is the power supply for the screen. Most manufactures call it a Blacklight Inverter Board. Most TVs have a " Protection Mode ". That's when the TV detects a bad circuit board and automatically turns itself OFF so it can protect the other components inside the TV. But, I can't say which board is the problem 100% because I can't actually look at the tv over the internet. I can only make guesses with the symptoms. I'm sure it going to be a power supply related problem.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under some extented warranty by Vizio, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 18, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
