Question about Exercise & Fitness
I need a replacement consol for nordictrac x7i incline trainer.
5 Suggested Answers
  • 34 Answers
SOURCE: Need to disassemble NordicTrack X7i trainer to
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Posted on Aug 10, 2010
2manyhobbies
  • 129 Answers
SOURCE: i have the Incline Trainer X7i. i lost the
Find the allen key that came with the treadmill. It is used to assemble and adjust the treadmill.
Locate the 2 adjustment screws at the rear of the machine. If the belt is shifting to the left, tighten the left screw (turn clockwise) and the same if the belt goes to the right, tighten the right.
Only turn the screw 1/2 turn and move the belt manually to shift the belt. If it requires more, turn another 1/4 turn, very little adjustment may be required to straighten the belt. Once the belt stops rubbing, start the machine running slowly (1-2 mph) and observe the belt FROM DIRECTLY BEHIND THE MACHINE. Carefully adjust the rear roller till the belt is as close to center as possible making small adjustments, 1/8-1/4 turn clockwise of the adjustment screws.
Posted on Dec 15, 2010
e-Guru
  • 3917 Answers
SOURCE: i have a nordictrack x7i
Hi
It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed.
Remove the console from the treadmill and remove the backRemove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).Remove and replace all the connections on the console.
Reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced. Nordic track does not sell just the touchpads. Check ebay for your console it would be the cheapest. there should be a part number on the console in the inside or on the back of the plastic.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 15, 2011
When turned on, the console just says IFIT and goes off, nothing else happens. Have checked the outlet and hit reset many times. I cannot turn the unit over by myself as it is very heavy.
Did you ever get an answer , I too am having the same problem. If you did receive any help can you email me.
jchaga13@gmail.com
I have tried everything .
Jan 06, 2016 | Nordic Track Incline Trainer X7i...
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
Belt slips on high incline x7i
there are two belt adjustment bolts on the front if your machine. tighten both clockwise and make sure belt stays centered. do this with it running about 2mph
Aug 30, 2014 | Nordic Track Incline Trainer X7i...
X7i will not power up
Hi.
Did you ever get to the bottom of this. I have the same problem. If you managed to fix it would you mind emailing me (mickclifford@hotmail.co.uk)
Jan 19, 2014 | Nordic Track Incline Trainer X7i...
Does anybody know what a bar that looks like its loading on the bottom of the screen ans nothing works means on my x7i?
Reset the machine with the small button to the side of the power button, and disconnect the machine power cord by 2 minute and toucht the small swithc with the eraser pencil make click.
Now try again. However if the problem persist try this:
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
God bless you
Nov 29, 2013 | Nordic Track Incline Trainer X7i...
The unit keeps turning itself off during a workout after say 20mins.It does come back on later ,but is very annoying
see the video and procedd according. Lube the rollers bearing front+back too. Test the drive BELT, and replace or tight a little.
God bless you
Sep 19, 2013 | Nordic Track Incline Trainer X7i...
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
Unit will not turn on
please see the video and fix it. God bless you
Jul 07, 2013 | Nordic Track Incline Trainer X7i...
How to troubleshoot Nordic Track X7i Console not turning on
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
http://www.sportsmith.net/images/product_support%5CNordicTrack%5C248194%20-%20NORDICTRACK%20INCLN%20TRAINER%20X7I%20INTERA%20TREADMILL%5CNTL20909.3-299073.pdf
Jun 19, 2012 | Nordic Track Incline Trainer X7i...
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
