Question about HP Photosmart C5180 All-In-One InkJet Printer
Usb port not working
I have hp pc & i have problem with it.when i plug in my mp3 USB for charging in the usb port its not disply on the lcd.i want solution for this. can u help me pls.
    President:
  • 2,185 Answers
After you plug your MP3 USB in your pc, switch the MP3 on. That would definitely work.
Posted on Jul 25, 2009
Usb 2.0 charging port doesnt work
The power connectors that are feeding the USB from the inside seem to be ok. The data connections of the USB are bad. Maybe with some very careful professional soldering of the data connectors on the inside of the USB, your problem would be resolved.
Jan 16, 2014 | HP Spectre XT Pro B8U92UT Notebook PC -...
My samsung YP-U4 mp3 player worked fine on friday, i plugged it onto the usb port and it charged. The next day, i plugged it onto the usb port and it doesn't charges, and the player doesn't recognize the...
Download the latest driver software from the Samsung website with the link below and install it on your PC. Click on downloads > Software.
If that doesn't fix the problem, try connecting it to other USB ports as the one you tried could be faulty or some USB ports do not provide enough power for the device to get connected.
http://www.samsung.com/my/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=&prd_mdl_cd=YP-U4AB/XME&prd_mdl_name=YP-U4AB&srchword=YP-U4
Mar 04, 2011 | Audio Players & Recorders
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
Sep 27, 2009 | Audio Players & Recorders
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
Jan 21, 2009 | Samsung YP-U3 MP3 Player
Charging my gpx ML638B
It will if it is a mini-USB plug. The mp3 has the mini-USB cord bundled, and can be used with anything with a mini-USB port. My cell has the same port, so I can charge it on the PC like the mp3, and can use the wall socket charger for the phone on the mp3.
Dec 18, 2008 | GPX ML648B MP3 Player
Doesn't look like its charging
Change the USB cable and/or PORT. If you have another device assigned to the USB port and didn't select to remove it correctly, the PC will not recognize the new MP3 player when plugged into that port. Simple fix... remove the MP3 Player from the USB, reboot the PC, then plug the USB cable back in. If it doesnt' recognize the MP3 you have something assigned to that port, possibly a printer and it will need to be removed before you can use it.
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
HP Photosmart C5180 All-In-One InkJet Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
